Question about HP Pavilion dv4000 Notebook
Installing the wifi antennae wires
I purchased the dv4000 direct from HP in 2005 and didnt think to include a wifi. I did eventually purchase an internal wifi card and the antennae wire but i have no idea how to route the wire inside the case. Right now, I have the wire coming out of the case where the card was installed and taped to the bottom and top of the unit for reception. I went the internal wifi card route because on this unit, no idea why, a pcmcia card would constantly lose the signal....any ideas on how to route the wire would be greatly apprciated.....Alan
  • aborack Jun 20, 2008
    Appreciate the response....was wondering too (and I should have mentioned it in the origianal thread) what to do with the ends of the antennae as they have thin, about 1.5" L x .5"w tabs that appear to be something you screw down in the case somewhere.
    Alan
    OK thanks gang --- I will open it up and sniff around for placement of the wires and then shut it down....Alan
  • 38 Answers
I have a acer5600 built in wifi adaptor my.My adaptor is fited to the center of my moutherbord the wires are fed out at the back crner up behind the screen i have two anntena top of each corner
Hope This helps in some way also try google adding wifi.ellis-y
Posted on Jun 20, 2008
  • Andrew Reed
    Andrew Reed Jun 20, 2008
    the anntena shoul be sticky tabd down at the back the holes shoul slip in to some littel bumps on the edge
    Problem Solver:
  • 7 Answers
My hp laptop has the wire up the side of the screen (inside up and over the top)
  • 85 Answers
You just have to route it through the case covering as much area as possible, as spaced out as possible. Also, the reason PCMCIA cards don't get very good signals is simply because they don't have enough space to have a properly sized antenna.
Use wifi on hp 1730 desktop
Most desktop PCs do not come with integrated wifi. Thus, in order to use wifi on these devices, you must purchase an wifi adapter for the device. This can be in the form of an expansion card installed internal to the device (assuming there is space to do so) or by using an external, USB dongle-style adapter (easier by far). Once you purchase the adapter, simply follow the installation instructions to install the hardware and load the driver software.
Jul 06, 2016 | HP Computers & Internet
I am thinking of purchasing this tv for a person who doesn't have an outside attenna and is too poor to purchase cable or a dish program. Can this set, a 22in. 720p model, work with an inside attenna? Is...
Any TV that has a Coaxial input can connect directly to an RF antenna. If this person lives near a large city, its likely they will receive more channels than if they live somewhere remote. Perhaps an antenna with a powered Signal Booster will improve the signal. Neither are included so I think Radio Shack has a good selection.
Jan 17, 2011 | Coby Televison & Video
98 plymouth voyager radio wont work. comes in as static. am works fine.
First start with pulling out the radio and make sure the antenna wire is plugged in. The last owner might have had an aftermarket radio in it and when they put the factory one back, forgot a wire. To remove it remove the trim ring (two screws I think) and then the radio screws.
May 24, 2009 | 1998 Plymouth Voyager
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Apr 18, 2009 | HP Computers & Internet
Cannot get radio channels
sounds like he didnt hook up the antenna wire.. check it out .. i bet this is your problem.. good luck keith...
Mar 20, 2009 | 2008 Hyundai Tucson
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
How to Disassembly the HP Pavilion dv4000 PC Notebook
click this http://hp.com click on support and drivers...type in your pc model(pavilion dv4000)on next page locate your model from list and click on it on next page on right hand side you will see other titles ...manuals is one of them click on it and in next page select service manual.they give step by step disassemble/assemble guide plus a pretty thorough fault repair guide
Jan 03, 2009 | HP Pavilion dv4000 Notebook
No antenna cables on toshiba satellite 1405 s151
Some models that come with a wifi card already in them have an antenna. Since you purchased your card after the laptop it does not have an internal antenna. You can purchase the internal antenna but this will require you to take apart your screen.
You could purchase a PCMCIA or USB wifi adapter and use an antenna with those devices without taking apart your laptop.
Hope this helps.
Jei
Dec 12, 2008 | Toshiba Satellite 1405-S151 Notebook
HP Pavilion dv4000 Notebook Logo
223 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
