Question about Panasonic KX-T7453 Corded Phone
Extention Display Name
I have read the Manual/Operating Instructions and I can't find how to change the display name on the extention. These people don't work here anymore and yet their names are still in the system.
    Problem Solver:
  • 14 Answers
This detailed instruction is not in the small book that came with the phone. It will be found in the binder or full sized publication titled “User Manuel’ for the models KX-TD816 and KX-TD1232 that came with the phone system.
You will want to use the overlay that DID come in the smaller book. You will place it on top of the buttons and it will provide programming commands listed in the instructions.
Page 71 has the “Getting into programming” details.
[Program], **, 1234
Now you are in user programming mode.
Page 87 will instruct you how to program names.
Press 004, [Next], [jack number] (ext 101 = jack #01-1, ext 102 = jack #02-1 ect…)
Once the jack and the old name are displayed, press [Clear] and then start pressing the letters according to the “Overlay”. (3 = 3 D E F) press the S-button that displays the correct character. S-buttons are the 3 buttons directly below the display. When you are done press [Store] and you can press [Next] to se more jacks or just exit by pressing [Program].
Posted on Jun 25, 2008
  • Eric Akau Jun 25, 2008
    Oh and this is very important, to do this type of programming you must be at ext 101!
  • christinagro Jan 28, 2011
    Thank you, this was a HUGE help. BTW, I was not at ext 101 when I did this programming and it worked just fine. =)
Voice mail display & retreving messages
Do you know how to get into phone system programming? The extension names are changed in there.
Mar 10, 2010 | NorStar M7310 Corded Phone
I would like to program the name of the user on each line for the associates in the office per their extension. so if they call eachother their name will come up
Depending on the type of phone, check the manual to see if you can change the extention number. If so you maybe able to replace the extention number with a name.
Oct 19, 2009 | Lands Phones
How do i change the name on the phone
This should be what your looking for..
From an individual extension with a Display Phone:
  1. Press [ Feature ] [ 0 ] [ 0 ]
  2. Press [ Left Intercom ] one time. The display reads: Enter Name (If a name was previously assigned to this extension, it displays instead.)
  3. Enter the two-digit code for each character you want to enter. (See Valid Entries below)
    For example, to enter the name Andy, press [ 2 ] [ 1 ] [ 6 ] [ 2 ] [ 3 ] [ 1 ] [ 9 ] [ 3 ] . The display reads: 12 ANDY
  4. If you make a mistake, you can press [ Mic ] to clear the display. Repeat Step 3 to enter the correct name.
  5. Press [ Feature ] [ 0 ] [ 0 ] to exit programming mode.
Valid Entires:
Letters A-Z, numbers 0-9, and blank spaces.
Character and Digit Codes:
Letters: Numbers:
A=21 N=62 0=00
B=22 O=63 1=10
C=23 P=71 2=20
D=31 Q=72 3=30
E=32 R=73 4=40
F=33 S=74 5=50
G=41 T=81 6=60
H=42 U=82 7=70
I=43 V=83 8=80
J=51 W=91 9=90
K=52 X=92 BLANK = 11
L=53 Y=93
M=61 Z=94
Mar 10, 2009 | Lucent PARTNER18 Corded Phone
I NEED TO CHANGE THE NAME ON THE WINDOW OF THE PHONE
wat system using?
find out the adminstrator phone (pic to set the speed dial)
must hv displayed phone.
press MODE will see PHONE NAME press HOLD display show ID DN it means key in extention number, after that key in name, press HOLD to confirm, repeat step for other extention name
press MODE untill time appear
Jan 20, 2009 | Toshiba DKT-3220-SD Corded Phone
Extention Recorded Name
Your name is in the Company Directory if you chose this option when you first set up your mailbox. To change it AFTER you set up your mailbox, press feature 9 8 1, enter your mailbox password, dial #, press ADMIN ( or 8 ), display should read
Mailbox admin
GREET PSWD QUIT
dial 1, at the tone record your name, press # to end recording, press # to accept, press RLS
It will look like you are re-recording your greeting but you are recording your " voice " name. Good Luck. ...Mike
Aug 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Changing employee name on extension
http://www.phonserv.com/1_m7310_phone_meridian_norstar_phone_system.htm
This has PDF file that will give instructions.
Also this link has more instructions:
http://www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_systems.htm
To Change the Name on a Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number (extension. you want to change the name on
5. The display shows "Reset Password"
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 30, 2008 | NorStar M7310 Corded Phone
HOW TO CHANGE NAME ON THE EXTENTION LINE
You will have to go into system programming. If you are not familiar with it, you will need to call in a professional, as it is too hard to explain over posting.
Dec 29, 2007 | NorStar M7208 Corded Phone
How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
463 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
