Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
H-D Wiring Synopsis 1978 FLHS Electra Glide (Without turn signals, spot lights or accessory lighting.) The last couple of years I have been having issues associated with the ignition and possibly the charging system. At the beginning of the riding seasons, I would be able to get a couple of 50 to 90 mile rides in, and then the bike would have difficulty starting. I could sometimes get it started by kicking or push starting it. At first I thought it was possibly related to problems with the Stator, Rotor or Voltage Regulator. Then at the end of the season last year, I was getting a slow turning over of the starter, followed by nothing at all, along with the ground wire on the battery becoming warm to hot. I had the starter looked at by a local reliable establishment, they installed new brushes. I presumed it to have a clean bill of health. This did not fix my problem. Presuming I had a short or poor grounding problem, I decided to install a new wiring harness. In doing so I had made sure all connections are made, and all contacts, were needed, had been wire brushed with a Drimal tool, assuring good grounding. With the ignition switch on, I checked, and had the following: Headlight (High and Low beams), tail light, brake lights (both front and rear), and horn. When I pushed the starter button, I got the slow turning over of the starter, followed by nothing at all. When I went to remove the ground cable from the battery, it was excessively hot. I double checked all the wiring to assure every wire was connected to its intended location. - Installed a new fully charged and load tested DieHard battery. Same result, a slow turning over of the starter, followed by nothing at all, and an excessively hot ground cable. - Installed a new starter relay. Same result, a slow turning over of the starter, followed by nothing at all, and an excessively hot ground cable. - Installed a new starter solenoid and cable from the starter to the solenoid. At the time of those purchases, I was informed by the service manager at the local H-D dealer that, if I would take a heavy gage cable, and connect it from battery to the small post on the starter solenoid, thus isolating my problem to just those three components, I could possibly locate my problem. Same result, a slow turning over of the starter, followed by nothing at all, and an excessively hot ground cable. This then told me my starter was bad. Even though I presumed it to have a clean bill of health, I purchased and installed a new starter. So, with a new Battery, Starter Solenoid and Starter, I use the heavy gage cable, and connect battery to the small post on the starter solenoid. This produced the same result, a slow turning over of the starter, followed by nothing at all, and an excessively hot ground cable. I tried to kick start it. No success. I do not know what else to try. Don Smith I can be reached at donsmith44@hotmail.com
  • 36 Answers
Sounds like a timing issue. If you have points set them to .018 and then static time the engine.
Hope you have that Shovelhead going by now.
Posted on Jan 03, 2009
Spot lights
either you got a bad ground, or bad main wire or you spots are too high of amps. for the wiring!
Apr 28, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
No rear lights, rear turn signals or four ways after removing a battery tender on a 2003 Electra Glide and Heritage Softail. What did I do wrong?
I do not know. Did you have the ignition on and power surge the tsm?? When you get the answer please post a comment and advise what it was. Thanks and good luck
Apr 26, 2014 | Harley Davidson Motorcycles
I have a 2001 electra glide ultra classic with the left turn signal lights up when applying the front or feaf brakeS and when i turn on the left signal the brake lights blink
First you check that the left turn signal and brake switch wiring haven't been switched. I presume brakes and turn indicators use different bulbs. Then you check for shorted wires from wear or crushing where they go from headlight
Mar 12, 2014 | 2001 Harley Davidson FLHTCUI Electra Glide...
Spotlights not working on my 1993 flhtc Electra Glide
Hi Anonymous, for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Nov 03, 2013 | Harley Davidson FLHTCUI Electra Glide...
2008 electra glide speedometer, turnsignal and brakelights not working
Hi Elizabeth, always check fuses and bulbs first for broken filaments. Then check the connection at the rear fender wiring harness, inspect for corroded, broken or loose pins. Use a dab of dielectric grease and repair as necessary. Check your brake relay if you have one , check your brake light switches for continuity, some models rear turn signals were single filament bulbs only, no running light. If all else fails get out your test light and start tracking the power wire from the harness connection. For a free wiring diagram please visit the website below and good luck:
Oct 10, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
Where is the tsm on my 2000 harley davidson FLHTC Electra Glide Classic
Hi Anonymous, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below. Good luck and have nice day.
Feb 17, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
2005 ultra blows the accessory 15 amp fuse when I push the right turn signal button. Any ideas?
Sounds like you've got a short in your right turn signal wiring. You need to check out the switch and the wiring between the power source for the switch and the turn signal canceling unit.
Good Luck
Steve
Apr 09, 2011 | 2005 Harley Davidson FLHTC - FLHTCI...
Brake lights,turn signal and horn not working...
Check the wiring within the headlight shell--look for connectors that may be corroded or pulled loose. A little WD-40 will favor connection integrity when sprayed into the connectors, then coupling and uncoupling them several times. Hope this helps!
May 24, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have a red key light and I have lost my turn signals and brake lights. I have running lights, head lights, cruise, spots and my security is working. The #2 fuse is blown, but when I change it it blows...
Sounds like bad brake light swich/sending unit.The one attached to master cyclinder.What happens to fuse if you turn ign. on,don't start engine,and hit brakes?Should bow fuse if switch is bad.
Mar 16, 2010 | 2005 Harley Davidson FLHT - FLHTI Electra...
No turn signal or 4 way flashers on 2000 flhtcui , all other lights working
The turn signal module gets it's power from the accessory fuse. If the fuse is good, check for 12 volts at the #2 position on the turn signal module (located on the top fork bracket). On the turn signal module the #1 wiring pin position is ground and the #2 wiring pin position is 12 volts dc. If there is no voltage using those two pins, check for resistance between pin #1 and engine ground. If resistance is greater than 1 ohm you have a broken or poor ground wire. If resistance is less than 1 ohm check for 12 vdc on both sides of the accessory fuse. If you have 12 vdc to only one side, replace the fuse. If you have 12 vdc to both sides of the fuse you have a broken wire between the accessory fuse and the turn signal module. If you do not have 12 vdc to the accessory fuse you have a broken wire from the ignition switch and the fuse block.
Nov 16, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Lands Phones Logo
306 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
