Question about RCA Televison & Video
Trouble shooting i have an rca proscan that will turn on display a picture then shut off
    Sergeant:
  • 260 Answers
This is a rather common experience in older televisions where the CRT or Tube is going out. If you bump the television and see a change in the function of the CRT then there might be a short. Either way I would recommend you either use our premium service or see our online resources to find a repair person near you. Good luck.
Posted on Jun 20, 2008
61"RCA Scenium modle number d61w136d When turning
You are on the right track, if the lamp is not lighting bright enough it could do this exact thing, the three tries is standard on RCA products, called the 3 strikes and your out---set will try 3 times to make it on and then shut down.
The color wheel while possible usually makes a high pitched fan like sound and with lamp out you should be able to see it to know if missing parts of the wheel or shattered.
12_18_2012_8_04_57_pm.jpgtypical color wheel.
Dec 18, 2012 | Televison & Video
I just purchased this tv. I had no trouble hooking up the satalite cable box but When I hooked up the dvd player the picture is only in black and white. How do I fix this?
Are you using component video (red/blue/green) rca jacks, or composite video input (yellow) rca jack? You need to match the color but watch out and do not get confused with the red and white RCA for audio.
Dec 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
36" RCA TV Wont power up
Best suggestion is IHVT,also known as flyback transformer.Thomson products well-known for xformer troubles. (GE,RCA & Proscan)
Oct 04, 2007 | RCA F36665 36" TV
Picture gone, Sound still exists
1)Try hard reset first==unplug AC cord overnight plug back in==see if it resets.If not,trouble- shooting w/service literature may be needed.
Apr 15, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
