Question about Sony Cyber-shot DSC-S700 Digital Camera
Wrong memory card size insterted
I inserted a wrong memory card size in my sony dsc s700 and it stuck! what can i do? can i open my sony or that would be wrong...?
  • 10,594 Answers
Opening of your camera would not be good because memory slot has very very little space in it and you can't do any thing, use tweazer to pull out that memory card.
Posted on Jun 21, 2008
My DSC-S700 said "No memory space in memory
Hi there make sure now your default storage place is external memory card. if it is then go in setting and format the card. Then restart the phone and see the result.
Jan 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I want to download photos from memory stick pro duo of sony company
Use card reader and insert your cams stick pro duo memory card/chip into it. Then insert card reader into Pc usb and copy your photos from memory stick pro to your pc.
Aug 19, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
HOW CAN I FIX MY MEMORY CARD IT SHOWS FORMAT ERROR C:13:01 ON MY SONY CAMERA SCREEN
Hi
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Oct 07, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
    Same problem when i inserted my memory stick duo, format error!!! f#@$#$ck
    not all memory card are functional to a certain camera. some cameras can't read memory cards that have big capacity. try to format your card through your pc and retry to insert it to your camera again if it works. If it dosn't work then it's not compatible. you have to change it.
    Sep 23, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
    I los tme cable for my Sony Cybershot.
    that is dangerous to camera to use wrong cable . a lot of cables will plug in but are not right even a aftermarket cable on ebay is better than wrong one.
    Apr 25, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
    Delete multiple pictures at one time
    You can delete all files by formatting memory card. Go to menu, select format memory, press ok.
    Mar 27, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
    Sony DSC-P10
    C:13:01 error code means memory stick/ card is unformatted or broken memory stick/ card. please format memory stick/ card, this option is available in camera menu and try again.
    If problem still there, use another memory stick/ card.
    May 30, 2008 | Sony Cyber-Shot DSC-P10 Digital Camera
    Magicgate memory stick wrong format
    ACTUALLY LOOKS YOU HAVE DELETED THE DEFAULT FOLDERS OF PICTS IN MEMORY STIC, NOTHING TO WORRY JUST REFORMAT THE CARD USING THE CAMERA AND IT WILL WORK FINE
    Apr 14, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
    Dsc-s700 format error
    If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
    Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
    Sony cyber-shot DSC-S700
    maybe you have to format it on the computer
    Jan 18, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
    Sony Cyber-shot  DSC-S700 Digital Camera Logo
    67 people viewed this question
    Top Sony Cameras Experts
    james laughton
    james laughton
    Are you a Sony Camera Expert? Answer questions, earn points and help others
