Question about Canon Pixma MP500 All-In-One InkJet Printer
MP500:not snecing or feeding paper
There is paper in the tray. It just printed but stopped midway. I had to force feed paper. Now it does not identify there is any paper at all. Keep getting the "Error, there is no paper..." dialogue.
  • martyhorn Jun 23, 2008
    Pixma MP600 After spending 73 dollars on the D ink because Canon makes us use color to print in black it now says no paper!!! There is plenty of paper. I want to sue Canon. Could we get class action against these thieves and robbers? I want my money back. What a rip-off company. What can we do when a company like Canon know us down and stomps on us??
  • Anonymous Jun 30, 2008
    My canon says error: paper output jammed.  There is NOTHING in there.  No paper, no paper shredds.... nothing.  I am really disappointed.  And of course this happens when the printer is needed most!
I just asked a question. Where do I find any answers?
Posted on Jun 23, 2008
Samsung clp 300 starts to feed paper but stops feeding (jams?) midway
This is a common problem with both this and the Xerox phaser 6110 (a rebadged Samsung)
It is due to the pickup roller "tyre" that is the rubber roller that pulls the paper from the tray.
It gets shiny and slips on the paper.
The cure is to "rough up" the roller with some sand paper or emery cloth.
The best way is to remove the imager unit and store it in a cupboard or a box IN THE DARK.
This stops toner getting everywhere.
Remove the paper tray turn the printer on its side you will see the roller underneath, using some sand paper or similar carefully rough up the rubber roller all round.
now put the machine back together and try printing it should be ok, if the problem persists try repeating the process.
Jan 05, 2011 | Samsung CLP 300 Laser Printer
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
Paper not fully feeding from paper tray. stops
  • Check for jams
  • Make sure all rollers are rolling and feeding
  • Make sure you using the manufacture required paper weight.
If none of the above applies to your issue you might have a bad feeder the paper is getting jammed mid way or there could be something inside blocking it half way thus your printer will need good maintnance.
Please do leave positive ratings for your free solution today.
Nov 17, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Paper feed problem
With that many labels I would replace the paper feed roller, RL1-0266-000, about $8.00
it will save you lots of headaches and a spare will fix it next time it happens.
Sep 01, 2009 | HP LaserJet 1022 Printer
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Printer PIXMA MP500
Check in the printer driver properties window on the computer. It sounds like the Paper Source is set to "Auto Sheet Feeder". You need to change this setting to "Paper Feed Switch" so that you can select the paper source from the printer itself.
Jul 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper feed problem
You need new feed components. Feed rollers and retard rollers or pads that stop multisheet feeds.
Dec 14, 2007 | Xerox DocuPrint N17 Laser Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
133 people viewed this question
old marine
old marine
Corne Viljoen
