Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Bp 511 i got a replacement battery and it is labled BP it is only 7.2V the one that came with the camera is 7.4V...is the replacement OK to use?...what is the suggested voltage?
Using too low of a voltage can injure some motors like the one that releases the shutter, but the folks at canon told me that 0.2V difference is OK...0.4V difference could be trouble.
Posted on Jun 22, 2008
    President:
  • 423 Answers
The BP-511's that are on my shelf are all 7.4V. The worst that could happen if you try the 7.2 in your camera is that it just won't work. I can't see that it could do your camera any harm.
Posted on Jun 21, 2008
Tip
Canon BP-511 Battery Maintenance Tips
battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
Canon digital cameras come in several different lines, some compact for easy travel and quick pictures, and others larger with multiple lens options and more power. the same problem many users have to encounter is the battery.manufacturers will tell to them how numerous hours that Li-ion notebook battery can last, however, they don't tell you how to maintain the battery.
There are more tips for you to change a common battery life, extend it for digital camera. One more simplistic method of increasing the lithium ion battery life by defragmenting the disc and remove excess folders. The suggestion for keeping your device for canon digital camera run powerfully with the hi-capacity canon bp-511 battery, which is a replacement battery, can be used recycled.
A lithium-Ion battery for canon bp-511 has internal circuit board with chips that allow it to communicate with the digital camera to monitor battery performance, output voltage and temperature. It also gives the notebook much more accurate 'fuel gauge' capability to determine how much battery runtime is left before the next recharge is required.
The battery for bp-511 battery provides uninterrupted reliable performance for the canon digital camera no matter you are on the trip or on the train travel, and want to record the sight.
This least quantity of time draws a considerable effect on the complete replacement battery life existence, the lithium ion bp-511 battery is 1600mAh, in fact if the battery can be used correctly, the performance of the battery can be used as the original battery, just depends on yourself. When in the hibernate mode in & out are extremely favorable and efficacious than the usual start & shutdown operation.
Talk about the battery storage, storage the battery in the normal temperature. When in hibernate mode the shutdown procedure grants a alternative to pause present work immediately with the power-off and when in start up activity it will keep on with in a few seconds entirely, As a result hibernate mode saving power. Do not modify or disassemble the canon digital camera battery under any circumstances.
Do not store a replacement battery pack near chemicals and in a damp area as this will reduce Notebook battery ability. The replacement battery is made with chemical material, take care of it, if you can.
more canon camera batteries discount now,like
Canon nb-8l Battery US $ 10.54
CANON NB-5L Battery £ 8.58
CANON NB-4L Battery US $ 6.71
CANON NB-3L Battery US $ 6.71
CANON NB-2L Battery £ 8.48
CANON np-e3 battery £ 21.52
on Jun 04, 2010 | Cameras
I have a canon EOS Rebel DS6041 and need to know what batteries I need If you could help please
Here's a page from an excellent forum "Steve's Digicams"
http://forums.steves-digicams.com/general-discussion/84527-canon-rebel-ds6041.html
As it explains, it basically a Canon EOS Rebel 300D and so uses the same accessories.
Here's a url for the Manual :-
www.cleaningdigitalcameras.com/pdf/EOSDR300DIM-EN.PDF
Here's a site for accessories:-
http://www.digitalmediastore.co.uk/Accessories.aspx?Model=DEV_CA_EOS300D
Said site mentions you want a Canon BP-511 or BP-514.
You can find them almost anywhere, Canon site/shops, ebay, amazon etc.
Good Luck.
May 29, 2011 | Cameras
Powers off wont come back on
Remove the two batteries and wait 20 minutes before reinstalling and powering on again.
Check battery voltages with a voltimeter. BP-511 should be at least 7.4V (you will probably measuere 7.8V).
CR2016 Battery voltage should be at least 3V.
Dec 12, 2010 | Cannon EOS 50D Digital Camera
Not charging video will not eject
CANON MV630I battery Specs:
  • Cell Type : LI-ION
  • Volts : 7.4V(Compatible with 7.2V)
  • Capacity : 4400mAh
  • Average Run Time :2-4 hours(minimum)
  • Color : GREY
  • Dimension : 55.10x38.20x39.90mm
  • Net Weight : 146.00g
  • Cpmpatible Model:
  • canon 5797a007, canon 5797a010, canon bp-508, canon bp-511, canon bp-511a, canon bp-514, canon bp-522, canon bp-535, canon pc511, canon vcn009, canon vcn009s, cta db-bp522, delkin dd/bp522, duracell drc522, empire bli-193-2.4, energizer er-c600, gp vcl008, hahnel hl-522, hama 46810, hama cp-810, optex li36, polaroid pr-522l, rayovac rv5462, sakar bp-522cl, sunpak hl-522s, techcell l522us, vivanco bp-22672decf09.jpg
    Jul 22, 2010 | Canon MV630i Mini DV Digital Camcorder
    Canon FS 200 battery pack communication problem warning-BP 808 ba
    You may want toget a battery that "New Canon BP-808 Equivalent Li-Ion Rechargeable Battery. Rated with 900mAh, the battery is made with info-chip, which can show remaining time on camcorder LCD. It also can be charged by Canon original charger and camcorder. It works wonderfully for and is 100% compatible with:
    Feb 13, 2010 | Canon FS200 Flash Media Camcorder
    Digipower BP-BG1 doesn't work in SONY Cybershot 220
    Take it back to best buy and get the original Sony battery.
    Aug 13, 2009 | Cameras
    Cannon A530 View screen has gone blank
    Usually this is beacause you press the button "visible", all camera have this button to choose the visible model of the LED, you can turn off it to save power to take more photos by view sight from the small sight window above the screen.
    bp-511
    Feb 11, 2009 | Cannon Cameras
    Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
    59 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
