Question about RCA HD52W59 HDTV Projection Television
Red,Blue,Green Image My picture has red, blue, green image. When tv is turned on, red, blue and green line appears across screen
  • Anonymous Mar 16, 2014
    Screen has three images, red/blue, and green. Looks like 3d image. How can I fix this?
    Genius:
  • 1,030 Answers
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Posted on Jun 21, 2008
SOURCE:
I have and 65" Mitsubishy HDTV model WS-65511 serial :118393 I never had a problem before but las week i was watching a program and sudenly a second blue image was on the scrren, i decided to open the...
there just might be a slight chance an adjustment of g2 high voltage to the blue tube might help however there is a good chance there is a problem with the tube
Oct 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Lines on the screen
Are they thin, white lines running east to west? If so, they are called retrace lines and indicate that the screen settings for the picture tubes is set too high or there may be a mal-function of the CRT driver circuitry. Try adjusting the screen controls which are located behind the front grill of the TV behind an access panel. Once you remove the grill and access panel, you'll see a small control assembly the has two sets of controls. Three for adjusting the red, green, and blue focus, the other, the red, blue, and green screen controls. To adjust correctly, put the TV on an unused input(dark, blank picture) and adjust until there are no visable retrace lines or color in the image.
michtech
Feb 14, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
314 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
