Question about Acer Aspire 9300 Notebook
Ethernet connection I purchased an acer aspire 9300 laptop. It doesn't have a driver for the ethernet connection to my router/internet. It will only work with a usb connection. When I looked online I could not find a download for this. Can you help me?
  • 2,028 Answers
Try these links. One of these should be the correct driver. If not, try You will have to register with driver guide, but it's free.
Posted on Jun 20, 2008
Acer aspire 5551 can't connect to wireless
Three potential causes that I can think of, the first is that the driver may be out of date or corrupted, connect up to the internet using an ethernet cable and go to maker site and update drivers; second it could be the router itself, is there anything else in the house connected to the router and if so then is that working (if not then that's your problem) lastly it could be the wifi card, if so then this could be replaced but it might be easier for you to buy a usb wifi adapter which is basically plugged into usb port, you load drivers from disc that is supplied and off you go (ebay around 6 pound)
Jan 10, 2013 | Computers & Internet
Wireless not working on acer aspire 5551a
Connect to internet using ethernet cable and update wifi driver from makers site, if this does not work then buy a usb wifi adapter off ebay or from a local store, put it into usb port and install the driver from the disc supplied with the adapter and off you go (far cheaper than replacing the wifi card)
Jan 10, 2013 | Acer Aspire 5536-5224 Notebook
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
We just purchased an acer aspire one for my daughter. When she tries to go onto the internet a message comes up that her internet adapter has been removed. Is this a device that plugs into a usb port? Does...
This computer has both ethernet & WiFi connection capability which should allow internet capability with the proper router.
Not sure why you are getting this message. I'd return it for exchange.
Aug 24, 2010 | Acer Aspire One A150-1006 Notebook
Ethernet-controller drivers for Acer Aspire 5520-5908 XP
Find a USB memory-stick, and find a computer with Internet access and an available USB port.
Put the memory-stick into the USB slot.
Browse to ACER's web-site, and select your specific model of the Aspire line, and select Windows XP, and select network-controllers, and download the device-drivers, and copy them onto the memory-stick,.
Walk the memory-stick to your Acer, and install the device-driver.
May 07, 2010 | Acer Aspire 5520-5908 Notebook
Trying to access the cd rom on a Acer Aspire 9300
When you go to safe mode, make sure that you go to "safe Mode with Networking", that way you can access the net. To make sure you have a good connection, get a long ethernat cable and connect it directly to the back of the router, in case the wireless driver fails. Get on the net forst, then try this site for your cd reading problem.....
Oct 14, 2009 | Acer Aspire 9300 Notebook
Acer aspire 5570-2609 driver
Following are the drivers needed, just copy them to a usb drive and then run them on the laptop:
Cd driver can be downloaded after you reestablish an internet connection.
Apr 30, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Jun 09, 2008 | Acer Aspire 4315 Notebook
Can't get internet access!!
The proper procedure in any router based network is to get the router on the network first. Plug it into the online cable modem and boot it up. Let it sit for a minute and then boot up wired computers one at a time. Use one of the wired PC's to get into the routers GUI (eg. and see if WiFi is turned on and the permissions or wireless access is not being blocked by any security settings like MAC address or IP filters. It should be wide open. You dont need ANY drivers for a router on a PC unless they are USB drivers for a USB connection straight to the router, never seen one but I have seen a cable modem/router that had a USB connection. If your laptop has a USB wireless device, you need to load the drivers for that onto your laptop, but if it is using the built in ethernet port on the rear or a PC card ethernet card, you just need to plug the ethernet cable to the rear of the router and boot up. Make sure your ethernet device is enabled in windows and you should be good to go. After you gain access to the internet on the wireless device, get back into your router, prefferably on the wired computer and lock your network down with security measures like MAC address filtering, WEP, or other means.
May 16, 2008 | Compaq Computers & Internet
Acer Aspire 9300 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
