Question about HP iPAQ H1910 Pocket PC
Sync problem with iPAQ 1910
The unit is almost 5 years old. The last six months I have not been able to sync with my desk top - I get a message that it cannot find the iPAQ. I have deleted Active sync and re-insatalled it and there was no change. Any suggestions?
  • Anonymous Aug 20, 2008
    It does not want to sync through vista. Is there a patch
  • Anonymous Mar 19, 2009
    my ipaq 1910 does not sync with vista. Is there a patch or future version that will synch ?
  • 3 Answers
Posted on Jun 26, 2008
IPAQ 4700 hard resetting on its own.
I also own an ipaq 4700 and experienced the same problem. Even after reloading the OS I continued to have this problem. I did buy it refurbished but I fear this may be a common hardware problem. From my research it would appear the battery is the most likely culprit, I have not tried replacing mine but it may be worth a shot, if nothing else you have an extra battery which means less time at the charger :D
Apr 16, 2009 | HP iPAQ HX4700 Pocket PC
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
HP iPAQ 110 will not active sync
no operating systems stated,
windows 10? what?
why would a battery this old be good, if was, its like world record.
buy a new battery ,better upgrade to smart phone.
sync
but the HP end and the Microsoft end have to have compatible and working drivers. to work.
the 110 is dead product at HP
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3544497
your only hope is talking to Microsoft now,
see if they support it, my guess w10 does not
how far back , support software drivers ended, ask MS.
looks like (hard to track) w7 is last OS supported.
i see scalpers selling drivers now, for this old product.
good luck with them,,,
try asking on a real HP forum
other asked this vast times, and the answers are dead correct.
http://h30434.www3.hp.com/t5/Calculators/Synchronization-involving-HP-iPAQ-110-and-Windows-8-PC/td-p/5078151
excerpted
Unfortunately, WMDC is not compatible with Windows 8 and you will not be able to sync your Outlook related data to your iPAQ. There is no expectation that Microsoft has any plans to update WMDC to make it compatible.
You may be able to use a third party paid application to sync the data, like Companion Link or Akruto Sync.
Mar 19, 2017 | HP iPAQ 110 Pocket PC
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
Regards
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
Activesync connection problems
this due to usb you just download hotfixes form microsoft updates and also download win xp service pack 3 which is available in windows site
Feb 15, 2008 | HP iPAQ rx1950 Pocket PC
When I connect my iPAQ to my PC, it will not recognize the device
It shouldn?t take more than 10 to 15 seconds for Active Sync to detect the iPAQ once it is inserted in the cradle and it turns on. First off you need to update to the latest version of Active Sync which is 4.5. Lots of synchronization issues have been fixed since 3.7 so here is the link to the download: http://www.microsoft.com/downloads/details.aspx?FamilyID=9e641c34-6f7f-404d-a04b-dc09f8141141&DisplayLang=en A couple of times over the past few years I?ve gotten a non recognition error as well. Each time I?ve been able to get away with removing and installing the latest version and my problem has been solved.
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
Calendar and outlook sync
Is ActiveSync set to sync only items from the last 2 weeks?
May 22, 2007 | HP iPAQ H2210 Pocket PC
Ipaq will not Charge
Those batteries only last about 2 years. It's probably time for a replacement.
Feb 15, 2007 | Compaq iPAQ H3870 Pocket PC
Error message while syncing Ipaq
open Activesync on your PC. Click on Tools, Options. Double click on calendar. On this screen is it set to sync 2 past weeks and ALL future appointments?
Sep 14, 2005 | HP iPAQ H5550 Pocket PC
HP iPAQ H1910 Pocket PC Logo
290 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
