Question about Kenmore 43142 Front Load Washer
Kenmore Front Load "tumble action washer"
My wahing machine is burning my clothes. It's leaving the pin hole burns from the drum, and streaks too. This is on a COLD setting. Does anyone know what's wrong with it????
  • erin_c Jul 11, 2008
    That was the problem with ours too!! I just found out last weel, and forgot to update this site. He said they're JUNK And not to bother with the repair that would cost over $600! We went nd bought a Whirlpool.
Our Sears repair guy says the tub bearing needs to be replaced. Get a new washer? Don't buy another Frigidaire...
Posted on Jul 11, 2008
  • amartinez1 Jul 14, 2008
    Anybody who finds this thread who has a similar problem should check out: http://www.appliancejournal.com/applianc...
    Sears refuses to make good on this bad deal or to hold Frigidaire accountable for their bad design.
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
Our tumble action front-loader washer just recently started leaving black marks in the pattern of the holes on the inside of the washer drum- We ran it twice without anything in the washer, and it still...
Thanks for stopping by:
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some de-greaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa!!
Aug 03, 2011 | Frigidaire 14 Cycle Tumble Action Washer
We bought a kenmore front loading heavy duty washing machine with 2-way tumble in Feb 2003. Recently two problems have become evident. First, our clothes have started to have black marks (streaks and...
Likely the cause is grease from a failing rear bearing.
Unfortunately, it's cheaper to buy a new washer than to fix this one. That's pathetic for a washer that's only 8 years old, and completely negates any environmental and economic benefits of buying a front loader.
Jan 29, 2011 | Kenmore 44102 Front Load Washer
Brown streaks on laundry. possible loose drum?
It may be correct. This may also be caused by oil leaking from the washer machine. Perhaps the heat is burning the clothes leaving the streaks.
The common cause of this issue are oil leaks.
Dec 27, 2010 | Frigidaire FGQ332ES Gas Dryer
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
Holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Jul 01, 2008 | Kenmore 43042 Front Load Washer
Kenmore 43142 Front Load Washer Logo
329 people viewed this question
Sal De
fordexpert
Robert Rankin
