Question about Frigidaire FAP094P1 Portable Air Conditioner
Obsolete part I am desperately searching for a 2 year old part. The internal water discharge pump for a FAP09EP1Z1 Frigidaire. I am absolutely dismayed that a 2 year old unit is considered obsolete? Is there an afte rmarket source for the pump? or other internal parts?
IFIXALL
  • 868 Answers
SOURCE: Water Leak
when you clamped it down you will have to add a 1/2 inch pipe ,about 5 inches is long enough.Use the pipe to clamp your hose to with adjustable clamps not Spring clamps.The pipe serves as a union here. Please rate this !
Posted on Jun 25, 2008
wbwill
  • 68 Answers
SOURCE: Noisey. when pumping ?
Have you checked with [assuming] your State's Attorney General Office? The third repair usually invokes the lemon law and requires that the supplier replace the entire dishwasher under warranty.
If you have not checked into that I would do that now and next.
This noise, from the pump, was the reason for the first replacement, or did it leak?
I cannot imagine them replacing a pump for noise, as noise, like hot, or cold is up to the individual what the parameters of PAIN are.
So let's suppose you cannot get a new dishwasher, and you have checked out the lemon law wherever it is you live, I will give you some technical answers and direct answers to your questions.
First, yes there may be a better pump, but these are generally not universal, the OEM pump is probably the only one that will fit, and should be the best available, anything aftermarket is generally not as good as the OEM [original Equipment Manufacturer].
I need more information on why the pump was replaced. Was it just noise? And did they run it in your presence after replacement, and did you buy off on it at that point? Then it got noisey again?
Now, next, a couple things could have happened, there could be noise baffles missing from the get go, or the first repair they left it out.
The pump could be cavitating, meaning there is not enough liquid, in the pump and it is swirling air.
Is the water pressure to spec, does the washer work or clean OK other than the noise?
There are so many possible reasons for noise from lack of water pressure, to missing baffles, to a bad product period, to the leveling is not right, to a clamp on a hose left off and when the machine calls for water the hoses slap or bounce.
This is going to be tough to settle over the phone, or email.
I would go to the seller and ask the same question then report back here, but before arm yourself with any lemon law data, and you could end up with a new washer for no charge.
There really are not huge differences in two pumps like this that would create noise, if there are two choices or more.
A pump could be made cheaper, the seals could fail quicker, but the noise thing, I doubt is a quality issue, something else is going on.
Will
Posted on Nov 17, 2008
  • 508 Answers
SOURCE: does not pump out water and does not spin
sounds like maybe sock or nylon clogging discharge?call repairman back out you should not be charged,cause its only been two weeks,i would ask him if he still has old discharge pump,be willing to bet it was ok! Alot of repairmen today are parts changers,instead of troubleshooters,they dont take time to get to root of problem,they just throw parts at customers expense!!!!(if repairmen gives you a line tell him you will contact states attorney general(he will have a certain amount of time to answer to state,allot of paperwork)you can report online)also you should call frigidaire they should be responsible for any maintenance of unit(warranty)-also run a inline water filter to unit-make sure your outlet is wired correctly(hardware store sells tester just plug in and it has lites that tell if wired correctly)-when you get solved find out how to properly store when not using(may be able to run something in it to properly coat internal parts) :)
Posted on Jul 05, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on Jul 13, 2010
  • 3247 Answers
SOURCE: i am a licensed plumber
I can see from what you have described (by the way it is a very clear and precise description which is very helpful), there is a problem in the water circulation system. These dishwashers use an alternating water flow method to split the water circulation between lower and upper wash arms in alternate cycles.
The way it is done is by use of a small ball that reciprocates between two holes in the water distributor. See item 58 in this diagram. It is possible this ball is blocking the pump impeller and causing the grinding noise.
You will have to open the assembly and check it out. You may need to replace some of the parts if the damage is too severe as there is a degree of precision required for the water jet to go through the right contour to create the flow.
Good luck. Take photographs at each stage so that you know what goes where.
Posted on Nov 24, 2010
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
I thought my water lines was frozen but after heating water line the pump won't kick on I can manually push the points on and the pump will run but won't stay on by itself and still doesn't pump water
The pump will probably need to be primed. Look for a drain plug at bottom of pump casing remove it and see if there is water coming out. You will need to get into the discharge side of pump to refill with water. Once you see water coming out of drain then replace and fill pump and line to where you broke into line (union joint). Then try pump once again..
Feb 21, 2015 | Plumbing
Water is leaking at the bolts. It is only 2 years old. Could it be the gasket?
might be a broken seal plate, or a shaft seal.. see picture on how to remove your pump and search you area for your local pool pump motor repair guy.. this might be a 20.00 fix .. shaft seal,o-ring or gasket ?
Jun 14, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
It is starting to make loud grinding noises
It does sound as if you have an issue with the pump it may have broken glass or some sort of debris that has already done internal damage to the pump impellor,especially if the noise has been there for a while.The one option is an inspection of the pump for wear or blockage.Hope this has helped.
Good Luck.
May 07, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Does not pump out water and does not spin
Jul 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Squealing sound
We have had the same problem and upon removing the main circulation pump, I found that the housing had come apart and had to order a new pump and install it. But the problem did stop there. The pump that discharges the dirty water has two stainless steel ball bearings in it and was worn out. So now I have to replace this pump also..... this needless to say, will be my last fridgidaire dishwasher. The unit is not ever six years old and might be used once a week.
Sep 02, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
My washer does not drain. Water accumulates even after the rinse and spin cycle. The machine does not overflow water. Could it be that the discharge pump is causing the problem? Second, if that is the...
BE CAREFUL FLOOD POSSIBLE
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Water Leak
Jun 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FAP094P1 Portable Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
