posted by jpglaspie on Jun 20, 2008
How do you reset to the factory default. Dlink describes the reset for the "B" version but not the A1 version which I have. Thanks
Jeff
Solution #1
posted on Jul 24, 2008
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for D-Link DES-3226L Networking Switch
Email this problem
Email this problem
Can you Help with these Networking Hubs and Switches problems?
my renter messed up the...
Got a call from a tenant that... Answer This...
Repair Service
Find Networking Hub and. Repairman Near You:
