Question about RCA HD52W59 HDTV Projection Television
Convergence Problem RCA HD52W59
My set is showing ghost images. When you turn the set on you see a red, green and blue line across the top of the screen before the picture comes on. Any test at the bottom of the screen is distorted.
    Problem Solver:
  • 35 Answers
You need to test all cables then make shure it is not your tv.
Posted on Jun 20, 2008
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
I have a rca from 2006 HD52W59 and it kinda looks like its in 3d and in a fishbowl len look to it what can this be? and it has a red, green and blue line acrossed the top
Thats a common problem that can usually be repaired by installing the RCA repair kit called ITC222 and ITC222A convergence option missing repair kit which is available from www.tvrepairworld.com
The kit contains the parts and the CD with instructions.
Aug 14, 2010 | RCA HD52W59 HDTV Projection Television
I have a projection tv that the pictures ghost and the red and green and blue do not line up on the screen. There is allso lines across the top of the screen and are red,blue,green. Looking at the screen...
You have a convergence problem. I have a tip which explains what this is, how to repair it and where to get the parts at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics . Let me know if this is not the problem or you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
Help!! The Image on the Television is ghosted and distorted!
This is a convergence problem that will continue to get worse. I repaired a few of these recently and found that the main problem was poor/broken solder connections at the flyback transformer. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
That being said, the flyback needs to be resoldered and the pico fuses close to it need to be checked and replaced should they be open.
The parts cost for this (even when replacing the 3 pico fuses) should not exceed $10.
Dan
May 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Television--the picture 3-d images colots red blue and green, been working great till this after noon any help please
When you presss menu and then select settings is the auto convergence and convergence options still there or have they disappeared/ Let me know and I will assist you with the problem.
Dec 17, 2009 | RCA HD52W59 HDTV Projection Television
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Bad or no piture
Hello gregxxx,
It sounds like you have a convergence amplifier problem. There are many articles on the Internet on how to do this type of repair yourself, but what these articles fail to mention is that if done wrong the chances are your TV will be damaged even more. So I would suggest that if you do not know electronics, for you to take the TV to a repair shop or have a TV technician come to your house to check and recommend a repair strategy for your TV set.
I hope this helps,
Thank you,
Shuttle83
Mar 24, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
191 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
