Question about Sharp AR-M237 Copier
Problem with Sharp AR 337
I am having problems filling the toner cartridge and replacing it in the printer and getting it to work. Any place to get good instructions for how to refill etc.
Thanks
Are you refilling the toner cart? if yes..
An easier way is to take out the whole developer unit. Pull down green handle as if you were replacing the toner, there is to the lower right of the developer unit a white handle that if you move to the right will allow you to remove the DV unit. Then there are 5 or 6 screws around the top edge that will allow you to remove the top and manually refill it there instead of trying to refill the cart and making a bigger mess.
Hope that helps...
Posted on Jun 20, 2008
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
Toner explosion
You need to either replace the toner cartridge or empty the sump on the front of the cartridge. The waste sump is in the front of the toner cartridge, It has filled up and has nowhere else to go but out of the sump and where ever it lands. Sometimes they fill up before the toner cartridge is empty. It happens
Jul 30, 2010 | Sharp AR-207 Copier
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
I don't know how to remove and install toner for my sharp ar-337
If you go here:
http://www.sharpusa.com/files/cop_man_ar287_337_407.pdf
You can download the operation manual for that machine, on page 4-5 they explain how to replace the toner and have pictures showing how.
here is the text on how to replace.
Adding Toner
1 Open the front cover.
2 Pull down the toner hopper lock lever and pull the toner
hopper out slowly until it stops.
3 Tap on the top of the toner cartridge 5 times. Hold the
new toner cartridge vertically and vigorously shake it
up and down about 20 times, then invert the cartridge
and again shake it up and down about 20 times. This will
loosen the toner and allow it to flow more easily into the
toner hopper.
4 Place the new toner cartridge with the tabs in the
notches as shown.
5 Slide the toner cartridge along the guides over the toner
hopper.
6 Hold the toner cartridge with one hand while pulling on
the sealing tape to remove it.
7 Tap on the top of the toner cartridge 5 times to start the
flow of toner into the toner hopper.
l If the toner cartridge was sufficiently shaken as described in step
3, it will take about 50 seconds for the cartridge to empty. Do not
remove the cartridge until it is empty. If not empty, tap on the top
of the cartridge again until empty.
8 Slide the empty toner cartridge back along the guides
and remove it.
l The cartridge opening will be closed as it is moved back along
the guides.
9 Slide the toner hopper into the copier and return the
toner hopper lock lever into place.
10 Close the front cover.
NOTE:
Add only one cartridge of toner.
Jun 19, 2008 | Sharp Office Equipment & Supplies
Sharp AR-163 Copier
replaced your toner cartridge with a new one, if you install a new one and it didn't work and still F2 flashes, the cartridge that you buy is not suitable for your country, always ask for a genuine toner, do not use compatible toners for your copier.
May 01, 2008 | Sharp AR-163 All-In-One Laser Printer
Sharp AR-M237 Copier Logo
110 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
