Question about Whirlpool Microwave Ovens
Powere went out and i now have a Touch Error reading on my whirlpool GH6177XPB-3 upon start up. Y High Fail 255 21 Y HiLo Pass 255 0 Y Low Fail 255 0 X High Pass 255 255 X HiLo Pass 251 5 X Low Pass 0 0 What does this mean and how can I fix? None of the touch menus work. thanks, eric 201-739-2750
    Genius:
  • 3,422 Answers
Your touch screen touch screen has failed.The only solution to fix this problem is to get it repaired.
If you need anymore help let me know.
Please don't forget to rate or accept the solution.
Goodluck..
Posted on Jun 20, 2008
  • 197 Answers
Sounds like the main control panel..
  • P.Michael D'Acre
    P.Michael D'Acre Jun 20, 2008
  • P.Michael D'Acre
    Eric, seems you have it under control, knowing that the board replacement is optional, since your device is still functioning. Let us know your decision on this.
Whirlpool gh6177xpb microwave error 252 on touchscreen at startup. How do I fix
clean ribbon cable that goes from pad to control board with denatured alcohol undo lock unplug cable clean contacts
Nov 23, 2014 | Whirlpool Microwave Ovens
Will not power up after power outage
it contains two fuses one of 10 Amps and other for 500mA.
Replace 10Amps fuse with same type and rating.Best thing is to take this fuse and show it to the sale person of electronic shop.
Before you touch any parts of the microwave oven please disconnect the mains power chord and never touch the main power capacitor as this contains very high voltage even after disconnection.
Mar 24, 2014 | Whirlpool Microwave Ovens
Whirlpool GH5184XPS Microwave Oven F7 error, trips circuit breaker
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Apr 01, 2012 | Whirlpool Microwave Ovens
KHHS179LSS-3 touch screen has stopped working. When I un-plug it and then plug it back in, I get a "Touch Error" message saying 'Y High Fail 255 95; Y HiLo Pass 255 0; Y Low Fail 255 0; X...
There is no reset other than unplugging the power for a minute then plugging it back in.
If this in under warranty I would contact the manufacturer via the information in your owner's manual for a free repair.
If for some reason you don't still have yours, you can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
If it's out of warranty, we repair these controllers for $39.95, or you can order an LCD assembly (part number ) from the Pros here or get a refurbished unit from us here.
Oct 09, 2011 | KitchenAid KHHS179L Convection/Microwave...
Touchpad does not work
This is a common touchpad error which we regularly repair for customers nationwide for $39.95 one year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 28, 2010 | Whirlpool GH6177XPS Microwave Oven
My g2 microven touch pad will not work, everything else works. I unplugged it and plugged back in ,shows touch error high fail 255 177 and low fail 246 0
Hello there
looks like you have a touch pad that has shorted out and is in need of replacement
please go to www.whirlpool.com and they have a technical help section ok.
best regards mike
Jul 31, 2009 | Whirlpool Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My KHHS179LSS-3 will not let you control microwave from touch screen un pluged unit plug back in touch error high fail low fail appears on screen
I was afraid I needed to replace the microcomputer when my KHHS179L touchpad was unresponsive. I was able to use the ADD A MINUTE feature, so I knew the unit worked. There had been a power outage of less than a minute to my home recently (I was unaware of this until I asked the kids if they had done anything to the microwave). I popped around on fixya.com and really didn't find an easy solution-my favorites. I loaded kitchenaid.com and found the answer in the FAQ's. Although the control lock out icon was NOT LIT-apparently, that power surge locked my controls. By holding the stop button for 5 seconds once and then aagain a second time, miraculously, my touchpad was restored> HOORAY!
Jul 10, 2009 | KitchenAid KHHS179L Convection/Microwave...
Model #mh7130xe made grinding noise then in line fuse blew
Did you replace the fuse yet?
Did the new one blow?
If so, and if it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If so, and if if it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the new one did not blow, and the microwave still makes a growling or grinding noise, but does not heat, you probably have a shorted high voltage diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 05, 2008 | Whirlpool MH7130XE Microwave Oven
Error Code
I would recheck the control board installtion that you made, as well as verify that you got the correct replacement. Also the board may contain static sensitive componets so you might want to make sure you are grounded when handleing the control panel. Good luck
May 14, 2008 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
471 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
