Question about Lexmark Office Equipment & Supplies
I WHAT IS THE POWER SUPPLY FOR THE MODEL X5470 PRINTER
  • 975 Answers
Printhead missing
What is the exact model of your printer? Try to take out the cartridges from the printer > re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds > when printer turns on, re-insert the cartridges. Try to print again to verify that the problem is fixed.
Jan 19, 2012 | Lexmark X5470 All-In-One InkJet Printer
X5470 constantly is powering on and off
Please try the steps below:
  1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
  2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
  3. Re-plug the power supply into the printer.
  4. Press the power button if the printer won't automatically power on.
If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
Nov 02, 2011 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x5470 does not turn on, and only a red light bright inside near the print injectors. Thank You.
Try to rebrick you printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will reset your printer.
If that doesn't help, try to plug your printer into a different known working power outlet.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
My lexmark all in one printer x5470 keeps jamming the paper and it wont print?or the paper will go in partially and print but nothing will happen then it will tell me to reload the paper and press the...
Most probably a mechanism problem. Try to remove all sheets of paper. Take out the cartridges from the printer. Close the cover. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Check for any obstructions or foreign objects in the feeder. Wait at least 30 seconds before plugging the power supply back in the printer. Once printer is ready, reload the cartridges. Load about 10-15 sheets, don't load too much. Let it print the alignment page. If this doesn't help, then most probably it's a hardware issue. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem.
Jun 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
My Lexmark x5470 keeps turning on and off, but won't print anything. Message says align paper, however the paper is fine, then it turns itself off and then back on to tell me the same thing. I've...
Try to focus on the printer itself first. Remove the cartridges from the printer, close cover then unplug the power supply. The power supply is the black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in the printer. When the printer's ready, reload the cartridges. Go through the alignment process. When it's done printing the alignment page, try to make a copy. If problem persists, I recommend you contact Lexmark Technical Support for further investigation. There might a hardware issue in the printer.
Jun 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
My x5470 shows light on copy mode only and if i try to press some thing else nothing happen
Remove the power supply (black box where the power cord is plugged in behind the printer) with the power cord still plugged in it and other end still plugged in to the power source/outlet. Leave it unplugged for about 10-15 seconds. Then, plugged the power supply back in the printer. Make sure to plug it in the correct position. Hope this helps. If not, place a comment so I can get back on this. Good luck!
Apr 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
My lexmark X5470 printer power button does not work.
Thank you for contacting Fixya.
Please follow the instructions given below to troubleshoot the power issue:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
3. Ensure you have the correct power supply connected to the printer.
4. If you have access to a voltmeter, please ensure that the power supply is giving out the correct amount of voltage (most of our printers use 30 volts output).
Your's tech support
Jeeth
Mar 31, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark x5470 everytime I try to fax it tries then beeps and say redial but it never goes thru.
Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... U will be able to send and recieve faxes..... Thanku.............
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
Aug 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
