Question about Motorola Mobility H700 Wireless Headset
Problems w/H700 bluetooth
My H700 bluetooth worked fine for 6-9 months, then the person on the other end could not hear me.  I hear them clear, however the person I'm talking to says it sounds like I'm talking under water.
I returned my bluetooth twice and got a new headset.  When I first receive the headset, it works perfectly, then again it works for 6-9 months and the problem occurs again.  Is anyone else having this problem?  What can I do to fix the problem?
It's frustrating because I've sent two headsets back.  If I send this one back, will I have the same problem after 9 months?
  • 7 more comments
  • davidlists Jun 23, 2008
    i have the same problem -- headset has worked fine and now other person cannot understand me. i'm using a blackberry 8100.
  • Anonymous Jun 24, 2008
    Had same problem 10 months after I bought it.
    I can hear people fine, but they cannot hear me
  • Anonymous Jun 26, 2008
    I have the same problem, I've had mine for about 10 months and it worked perfectly. Now, the person on the other end can't hear me or I sound muffled. Help :(
  • Anonymous Jun 28, 2008
    I have the same problem except that the problem occured earlier than 10 months (roughly 4 months). I had already exchanged one that didn't work and now this one has stopped working. For months I could hear people but they couldn't hear me. I won't buy another Motorola.
  • martini780 Jul 02, 2008
    I have now had two H700's with the same problem....it works great for 8 months then it still sounds good on my end but person on other end can bearly hear it. This occured on my blackberry and a samsang phone.
  • Anonymous Jul 04, 2008
    CAN NOT HEAR ME
  • rleon914 Nov 18, 2008
    Absolutely identical issue. Is there any other answer than buying a new one.
  • Anonymous Nov 20, 2008
    I had the same problem. I was able to use mine for almost 2 years though. It worked fine and then the next day no could hear me at all. It was like the mute button was on. I tried muting and unmuting it but that did not work. I will try cleaning the mic with a needle. Hopefully that works. I was very happy with the device until now.
  • Blaque Berry Nov 26, 2008
    how do i unmute the h700. please email me at dj_blaqueberry@yahoo.com
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
Posted on Jul 07, 2008
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
My H700 bluetooth, I can hear caller but they can't hear me!
The average life of a Bluetooth Earpiece is usually a few years. When you are having symptoms like you are describing it usually means that the Blutooth headset is at the end of its service life. You might want to cintact Motorola and see if they will Warranty them.
Aug 22, 2012 | Motorola Mobility H700 Wireless Headset
H700 is paired...I can hear the caller but they can not hear me? Any help would be appreciated.
I actually had this same problem within the 1st year I had my H700 headset. I had to carefully pry open the flip end and remove a small piece of fabric that had been put inside by the manufacturer. After I had done this, everyone I talked to when I used the headset could hear me just fine. I am not really sure why it worked since all I did was take out a tiny piece of black fabric but it seemed to. I was able to also close the flip end back up as if I had never opened it and it still stays closed. I have still been able to use the headset even after about 5-6 months later but I did get an extra headset to have around if I need it.
Sep 29, 2009 | Motorola Mobility H700 Wireless Headset
I can hear the person on the other end but they can't hear me.
To mute or unmute the headset, tap both volume buttons at the same time.
Mar 29, 2009 | Motorola Mobility H700 Wireless Headset
Bluetooth conection
This may not be the solution for your problem, but I'm sure you'll like the way I'm thinking... ;- )
I also have an H700, and the clearance from my cheek to the microphone aperture is small--maybe two millimeters. I've had a couple of occasions during the summer when I was working outdoors in the heat, and my sweat bridged between the mike boom and my cheek--my callers told me I was unintelligible. With the sweat wiped away and the mike aperture cleared, all was well again.
If you're sweating during use, that may be your problem. If it's a continuous problem, maybe you have something mashed into the mike aperture...?
Sep 12, 2008 | Motorola Mobility H700 Wireless Headset
H700c, I can hear butothers can't hear what i speak.
With this problem, the headset will have to be replaced.If you had it less than one year Motorola can replace it free of charge with purchase recipe. contact Motorola.
Jan 27, 2008 | Motorola Mobility H700 Wireless Headset
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
Was working fine until now.
uninstall device and try to reinstall if this doesn't work go to www.n1wireless.com about 30 bucks
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
239 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
