Question about Geovision GV-800-16 Video Capture
Geovision GV 800 video lost
I have a remote restaurant in San Antonio and they have total video lost.
I know its not the cameras since the back door camera has its own power supply. I had them check the connections and everything looks good.
Im not sure if it could be a bad cable (where all the cameras plug in) or the card is having issues.
I checked the drives and they are all installed. Any suggestion of what to try next???
Thanks
Bethany
  • 4,472 Answers
Uninstall and re-install the drivers first. Let me know what that does.
Thanks,
Lee
Posted on Jun 20, 2008
I see pink boxes instead of video output, when I log in through my remote pc. I use Team Viewer to access my security pc.
Posted on Mar 10, 2011
I have gv 800 card using V8.5 software, i have five cameras connected but it only displays 4
This is not a big issue u ant watch 5th camera coz u had stopped other 122 cameras from working in GV eries you are allowed to stop remaining cameras from working to avoid video lost beep and video lost screen you can again start remaining cameras from here:in main menu (configure) 2nd option from top CAMERA/AUDIO INTALL ===> click on activate ===> activate the cameras as muich you want hope my post helped u
Dec 28, 2011 | Geovision GV-800-16 Video Capture
Reinstating a 7 camera system on a house. known to have been based on GV 800. hardware and software all installed with no error messages. only one camera actually displays a picture - the rest just say...
The geovison cards have quite a few issues with winXP and up because of the way they switch inputs. Windows don't seam to know how to handle it, i would try installing the drivers for the device again. You should see 4 video capture cards as well as a pci-bridge installed.
I also highly recommend Zoneminder for cctv. http://www.zoneminder.com/
Jul 04, 2011 | Geovision GV-800-16 Video Capture
On all cameras it says lost video
I assume you have multiple camera's and have checked that at lest one has power :-)
If so, most likely the PC has lost the cards License Key .. try uninstalling the camera drivers & re-installing.
Aug 22, 2010 | Geovision GV-800-16 Video Capture
GV800 software keep rebooting, anyone has any idea what's the problem is?
sounds like one of your cameras lost connection and the system is rebooting because of that. check the general configuration screen and make sure the reboot on exit is not checked, also check all of your camera connections to make sure they are all ok and receiving video on all channels.
Jun 24, 2009 | Geovision GV-800-16 Video Capture
Cant view vedio log on GeoVision GV-600
Okay - try going into the software directory and delete the files maked .db there should be one for each camera. Then start the software and try it again.
May 14, 2009 | Geovision GV-800-16 Video Capture
Do any1 know is it possible to use 2 Geovision Gv 800 in one PC?
yes you can, but recording will depend on size of hard drive. i work in the trade and you will require at least a terra bit to run 32 cams for any given period
May 07, 2009 | Geovision GV-800-16 Video Capture
Gv-800
This problem could be because of the GV card version not compitable with GV main systems software you install please check the hardware version of the GV card and compare for compatibility. East way out downgrade to lower version of software. for example if you have version 8.1 install then install version 7.0 or something like that.
Aug 27, 2008 | Geovision GV-800-16 Video Capture
"Lost Video" error
Which version of the card are you using, BNC or D type?
Remember: GV-800 is currently not compatible with VIA series and ATI series chipset motherboards.
I know Dell uses mostly Intel chipset, but just in case, check with your motherboard to see if you don't have either ATI or VIA; specially since you already have the nVidia.
Try going to the BIOS on your PC and set the 'Primary Display' to PCI instead of the built-in chip.
If you have more information, please let us know. We can help you better!
Feb 01, 2008 | Geovision GV-800-16 Video Capture
Geovision GV-800-16 Video Capture Logo
3,865 people viewed this question
Top Geovision Televison & Video Experts
Rommel Balcita
Mark Magill
Mark Magill
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
