Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
BLACK AND WHITE PCITURE ONLY WHILE SETTING UP MY TV OUT CABLE FROM MY LATOP
HI THERE I CAN ONLY GET A BLACK AND WHITE PICTURE THROUGH MY TV OUT CABLES EBRYTHING IS SET UP AS THE INSTRUCTIONS SAID SO AND ALSO THERE IS NO SOUND BY ANY CHANCE COULD U HELP ME WITH THIS PROBLEM PLEASE THANK YOU
    Sergeant:
  • 260 Answers
Hello. What I hear you saying is that you have a TV out cable that only produces black and white on your television. That sound very frustrating.
I assume that means you know the TV works in colour if used for local channels. First, try replacing the cables connecting to the TV out connector. Second, make sure the device with the TV out connection is functioning well. One way to test this is by using another device to check and see if the problem persists with multiple devices. If you find colour from the alternate device, then the problem was in the receiving device. If the problem persists, please consider using our premium services or using our online resources to find a repair person near you. Good luck.
Posted on Jun 20, 2008
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
The tv is connected to a dvd player and someone was playing with the buttons, now the picture wont stop rolling
It is possible that the MODE of TV SYSTEM was shifted possibily from PAL to NTSC and so the pciture can roll or be in black & white.
So open the menu and check the settings, look for TV system , colour system and change.
Jul 21, 2011 | Sansui 19 in. LCD TV
When u put a dvd in it shows coloured,but regular tv channels shows black and white
Most likely the cable between the cable/satellite box and the tv is not fully home. Push all the connections firmly home and try it again.
May 03, 2011 | Televison & Video
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
Connect ps3 to a non HD tv and picture only black and white?
Are you connecting it to a new SD tv after having been connected to an HD set? You can force the system to reset the video resolution settings by pressing and holding the On/Off button after the system has already turned on. I believe it is ~5-10sec. You will hear another beep after the initial startup beep. This will reset video setting to default and go through the resolution setup wizard again.
However, it is also possible that you are trying to connect a component cable to a composite tv. They are VERY different signals even though the cables fit interchangeably. If you use the Green component cable for video on a composite tv you will only see a grayscale image of the picture. This is most likely your issue. If this is the case you will need to buy a composite cable for the PS3 (the PS2 one is the exact same as the PS3 one.)
FYI Component cable has Red, Green, & Blue cables. Composite has Yellow (Video), White (Left Audio), Red (Right Audio). Both are normal RCA type plugs and will fit in each others plugs, but the signals are VERY different.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Playstaion Shows only in black white
Try manually resetting the video.
While the PS3 is off,
Press and HOLD down the POWER BUTTON
When you hear the second beep, QUICKLY release the power button.
Let me know what happens.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
Samsung DVD-V3500. DVD sound okay but no visual picture - a lot of white rain on black background.
what cables uusing hdmi or yellow video cable or s video try oher cables and other out puts did sumone stick outpyt mode on full hd and maby your tv cant handle that setting
Oct 07, 2008 | Televison & Video
Im getting black and white picture from my s-video output
TV display only black & white alway due to wrong system setting ( NTSC or Pal ).your may need to adjust your TV setting. hope it help
Oct 03, 2007 | Dell Inspiron 6400 Notebook
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
