Cannot fax using epson bx300f
This response is a little late, but it's because you all appear to have something other than an Epson C86, under which your problems are listed! Eoromarts problem is super-generic. It could be due to hundreds of reasons ranging from "because I was in Blackpool at the time" to "my wife had borrowed the modem cable for a washing line". Come on, you need to give a lot more information than that!. McFax - your problem is simply not understandable please be much more specific!.
However, we may be able to help Stretchyd who has provided actual information on his problem. You cannot send faxes by Broadband. You need a good old-fashioned dial-up modem (which we all used to use to connect to the internet before broadband). You clearly have one of these, otherwise you wouldn't be able to receive faxes.
So you should have a cable from your Broadband modem to the phone line, going into the broadband (DSL) filter ADSL port. You should also have a cable running from your dial-up modem socket into the broadband filter phone port (you may also have a phone going into this, so you will need a phone socket doubler to take the phone wire and the dial-up modem wire).
So, to send a Fax, you need to run your Fax program (usually the Windows XP fax module) and set up your system for dialling out. If you need help with this post a new connebt.
