Question about HP LaserJet 3015 All-In-One Printer
HP 3015 No fax detected
Hi, my company has a HP laserjet 3015 and gets "no fax detected" error, We have a dedicated fax line and have tried switching the cables and even where it is patched? Any assistance would be greatlyappreciated.
Thanks
Paul
  • addybest Aug 12, 2008
    You can change the settings on the control panel of the printer.
    1) restore the printer.
    2)turn off the ecm (error correction)
    3)turn off the v.34
    4)turn on the silent detect.
    in case we still have th same issue
    then select the menu button once
    then select the * & # together
    u will see the developers menu
    then with the help of the arrow keys check for the r/w parameters
    select enter
    type in the value 153 and select enter
    change the values to 6
    select enter.
    printer will be back to the ready mode.
    then select same options.....
    go to r/w parameters again select enter
    type the no 159
    change the values to 6 again
    select enter
    now try to send/recieve faxes
    it should work.
    if not try the firmware upgarde from this link
    http://h20000.www2.hp.com/bizsupport/Tec...
    u shpuld be able to get it working now.
    if it still doesnot work then the fax modem has a issue.
    get the printer serviced.
  • Anonymous Mar 17, 2014
    hooked to phone line. I can send but cant receive.
I am having the same problem
Posted on Jul 03, 2008
Did you ever get a response to this? i am having the same problem.
Posted on Jun 30, 2008
Recieve faxes problem in hp laserjet 3050
- cables properly connected
- analog or digital (DSL, VoIP, etc) phone line
- dedicated line?
- under fax setup, all faxes, turn error correction off
- under fax setup, all faxes, turn v.34 off
- test fax
Jul 17, 2010 | HP LaserJet 3050 All-In-One Printer
Unable to receive fax on HP 2840
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } There would not be problem in phone line. please slect appropriate option in data fax mode.
slect it to the recieving mode.
hopefully it will work fine
Sep 03, 2009 | HP LaserJet 2840 All-In-One Printer
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Hp laserject 3015 comm error 252
It is most probably the problem with line. Try to call from you fax machine and check the line condition.
Mar 24, 2009 | HP LaserJet 3015 All-In-One Printer
Will the hp laserjet 3015 fax work with mediacom phone service?
Anything made in the last five years is generally designed to support digital phone lines and the product should be compatible.
Best regards,
Mediacom
Jan 06, 2009 | HP LaserJet 3015 All-In-One Printer
HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
HP LaserJet 3015 All-In-One Printer Logo
2,677 people viewed this question
Ben Johnson
