Question about GE Monogram® ZBD6880NSS Stainless Steel Dishwasher
GE Monogram ZBD0700K - gel pak detergent not dissolving
Undercounter built in has been working great since day 1 using Electrosol gel pak detergent. Recently the gel pak is on the floor of the dishwasher once cycle is complete...dishes very hot, but not clean. Phoned both Electrosol & GE & was told to ck the water temp, water pressure and to be sure nothing is obstructing, etc. All is the exact same as has been since day 1 - hope you have an easy solution!
  • 84 Answers
Low inlet water Make sure inlet water temperature is at least
120°F (49°C)
Run water at the nearest faucet prior to
starting the dishwasher to insure optimal water
temperature.
Water pressure is low Turn on a faucet. Is water coming out
more slowly than usual? If so, wait until
pressure is normal before using your
dishwasher.
Air gap is clogged • Clean air gap.
Improper rack loading Make sure large dishware does not block the
detergent dispenser or the wash arms.
Posted on Jun 20, 2008
D/w doesn't dissolve deterg. & therefore not washing dishes
Do this test:
-Upgrade to a name brand detergent like Cascade or Electrosol.
-Do not over fill the dispenser cup
-Do not place large items near the door/near the dispenser cup.
-Make certain that both spray arms can spin freely after you load the dishwasher but before you close the door to begin the wash.
Please report back what you find, OK?
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Gel paks don't dissolve
Before you start the machine make sure the water is hot enough going into the dishwasher. Sounds like the water temp is not hot enough to melt paks or dispenser is not opening.
Feb 24, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Detergent not dissolving
Are you getting any error code that indicates you have a motor failure? If not:
The LF LDF6810 is a water conserving dishwasher that requires quality detergent. Buy a box of name brand powder (e.g. Electrosol pr Cascade) Do not use ultra-cheap, generic detergent and never use gel or tablets in any dishwasher.
If you still have cleaning problems problems, remove the lower wash arm and the 9 screws that hold the filter beneath the spray arm.
Pull the filter out and rinse thoroughly.
With a flashlight, inspect the sump area, removing all debris.
So try this before you go deeper. I have had the same problem with my LG 8812 and this solved my problem.
Apr 09, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher wont dissolve soap and not washing properly
The make and model number can probably be found around the door edge (usually right side) If you can find it, post the make and mode # here.
Recommend you get a box of brand name detergent powder (like Electrosol or Cascade) and begin only using that. (Neve use gel or tablets) Cheap Cheap, generic detergent does not dissolve properly, leaves residue of its own and cleans poorly.
If problems continue, check the heating element as it is very possible that it has failed and the dishwasher needs to get to the proper temperature to activate the detergent. Also check to see if the holes in the spray arms are not blocked with debris.
If the heating element is working, then the wash pump motor has begun to fail and you need to decide to replace it or replace the entire dishwasher.
Apr 08, 2009 | Dishwashers
Dishwasher detergent won't dissolve
Recommend you stop using the gel and switch to a brand name powder - like Electrosol or Cascade. Never use gel, gel packs or tablets in any dishwasher. Avoid untra-cheap, generic powders.
If problems continue, a service call, with them checking that the heating element is working is the follow up step.
Good Luck!
Apr 02, 2009 | Whirlpool DU930PWSS Stainless Steel...
Detergent caked in holder after running a cycle, using Cascade
Try this before you jettison your current dishwasher. Yes, it is possible that the wash motor is getting weak, beginning to fail but:
Buy and use a box of brand name box of detergent powder Electrosol or Cascade. Stop using the generic powder and never use a gel or tablet in a dishwasher.
You will be amazed how how much better the detergent dissolves and the DW cleans.
Good Luck!
Mar 31, 2009 | GE 24 in. Profile PDW7800 Built-in...
Doesn't clean dishes completely, especially the top rack. also it doesn't completely empty out the detergent dispenser.
To the people here with the poor cleaning problems:
Try these steps:
Buy a small box of Cascade or Electrosol diswashing powder. Use only it for 30 days and report back. Do not use gel, tablets or ultra low end detergent. I have proven that ultra cheap powder WILL cause problems.
Also, fill a bowl or large cup with white vinigar, place it in the bottom shelf of of the empty dishwasher. Do not add any detergant. Run a normal or quick cycle.
If you still have poor cleaning, it is time to call for service or remove the filter beneath the lower rack and search for debris that will need to be removed.
Please report back with your results and the make/model of the dishwasher. Good Luck!
Dec 22, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Soap left in the dish
With the LG LDS5811 dishwasher and other water/energy saving dishwashers, they are VERY ineffective with untra cheap powder detergent. Switching to Electrosol or Cascade has solved the problem -- and don't use too much.
If you add a whole house water softener, you will be AMAZED how much better your dishwasher and clothes washer work -- especially if your cut down on the amount of detergent your use.
Oh, never use gel or tablets in your diswasher. Ever.
if the problem with the detergent dispenser not opening is a seperate problem. Recommend you submit a seperate problem/question.
Good Luck!
Aug 26, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Re:dishwasher
Ginga, first of all it's still under warranty so I would call for service. Here's a few things to consider; first, I would switch back to the powdered detergent like Cascade. You want to make sure that the water entering the dishwasher is at least 120 to 150 degrees, anything less will cause the detergent not to dissolve. Check your loading and make sure nothing is blocking the spray arms from the soap dispenser. Make sure the spray arms do not have any cracks or splits. After the dishwasher fills, make sure that the water level is right at or just below the heating element, a short fill will cause this also. Catriver...post back.
Nov 04, 2006 | Kenmore 24 in. 16182 / 16189 Built-in...
GE Monogram® ZBD6880NSS Stainless Steel Dishwasher Logo
322 people viewed this question
Top GE Dishwashers Experts
Mike
Ned Halaweh
Ned Halaweh
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
