Washer filling up with water but nothing else.
I have a roper washing machine (RTW4340SQ0) model I think. Can not find the book. I will fill up with water but nothing else will happen after that. I think it is only about 4 or 5 years old.
Angie
  • maknithapn Jan 24, 2009
    I have the same problem...washer will fill with water...stop and do nothing else. Any help would be greatly appreciated.
  • 1073 Answers
SOURCE: Cold water not running.
check the cold water selenoid on the water valve
Posted on May 05, 2008
  • 1028 Answers
SOURCE: washing machine won't stop filling with water
if it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Posted on Nov 19, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
  • 9 Answers
SOURCE: Have a Roper Model RAS7133RQ1 washer turns on won't wash etc
hi there i think the problem is that your big end has blown and this is affecting your gangle pin you will need to replace these and these are very cheap and available from any hardware shop your friend MR FIXIT
Posted on Apr 26, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Posted on Jul 24, 2009
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
I have a roper Model # rtw4340sq0 that when on the "super" water level setting, just continues to fill ( and drain) when it gets to the rince cycle.
Sounds like the water is siphoning out of the drain hose.
Check the drain hose behind the washer to make sure it's higher then the high water level in the washer.
Aug 03, 2011 | Whirlpool Washing Machines
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Jul 24, 2009 | Washing Machines
Apr 26, 2009 | Roper Washing Machines
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
May 05, 2008 | Washing Machines
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
