Question about Belkin (F5D5231-4) Router
Can't connect wirelessly to Belkin Router
I have a Belkin High Speed Mode Wireless G Router. For the last 2 years I have never had a problem with connecting wirelessly. However in the last few weeks both my computor and my boyfriends laptop have been unable to connect to the wireless network. Both can now and again find the wireless network however cannot connect to it when they do find it. However the computor downstairs which is connected to the wireless router via an ethernet cable can access the internet with no problems. We have tried changing the router to another Belkin one, however the problem still persists. I was wonderign if anyone has had the same problem or knows of a solution.
Many Thanks
Grace
Hi, I have tried all the different settings on the router and as far as I am aware there shouldn't be anything interfering with the signal as we have nothing else that is wireless. I just can't figure out what It may be lol!
Posted on Jun 21, 2008
    Novelist:
  • 143 Answers
Have you customized the wireless settings of you router (e.g. ssid, wireless channel, wireless security)? if not, try to change your router's ssid or the wireless channel. it could be that some wireless devices are interfering with your signal.
hope this'll help you.
ciao!
How to encrypt router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Mar 02, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
Slow connection speed
Blu Ray players, draw alot of interference into the wireless router. Try moving your router into a different place, or somewhere away from your Blu Ray player.
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
I have a Lynksys Wireless-G brand WRT54G2 router connected to my High Speed Ethernet Modem and to my desktop computer. It puts out a fairly decent signal to my laptop across the house through walls and...
Yes. 1. Disable the DHCP in the belkin router. 2. Take the cable from the LAN port of the Linksys router to the LAN port of the Belkin Router. 3. Dont touch anything else in any of the routers.
This should help
Thanks Ranjit
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Oct 17, 2009 | Belkin (F5D7231-4) Wireless Router
Belkin wireless n route only puts out 54mbps
The reasons you only get 54mbps could be: one, your networked PCs don't support N-mode and broadcast in G-mode, so that the router falls back to 54mbps.
Two, the signal strength is too low or the radio noise level is too high to allow N-mode operation at full speed.
So, after checking with the manuals and vendor brochures, you should try connecting the router with a single PC close by - say, ten feet in the same room - and check connection speed. If you can connect at 108 or 125 depending on which N mode you have (N, N+, N1...), the problem is likely to be distance, walls or noisy equipment.
If you still can't connect, double-check the configuration of both router and PC (wifi board "Advanced Properties" in Hardware Management) to check whether N mode is enabled at BOTH ends, especially "Wireless Mode" in the PC.
If it still doesn't work, I'd test it with a Belkin N USB key, for example, just to check that when router and client vendors say, "802.11N", they do indeed refer to the same thing. That's not so cut and dried a thing as one would expect. The N-mode standard was not completely defined from the start, so that many vendors jumped the gun and implemented their own "N-modes" which are often NOT compatible with each other. If you had a US Robotics router and a Yuwasa (and outdated SparkLANs, IIRC) wifi board, you'd discover that you could only attain 11 mbps - and if the USR router was set for "G only" or "G and N" instead of "B, G and N", you would get no connection at all.
Oct 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless connection speed at 11mpbs. Why not 54mpbs?
this is from the d-link support page:
"Question :Why can't I get the advertised speed and performance when in Ad-Hoc mode?
Answer :
This FAQ applies to 802.11b, 802.11g, and Super G™products.
D-Link wireless products follow the IEEE 802.11 standards. The802.11b and 802.11g standards specify that Ad-Hoc mode only needsto support up to 11Mbps. For best results, use an access point orwireless router and set your adapters to Infrastructure (station)mode."
Feb 03, 2009 | Belkin (F5D7000) 802.11g/b Wireless...
Wireless Router
Belkin G plus or equivalent. With so many computers connected to it, possibly at the same time, you need the fastest transfer speed possible from the router to the computers. Additionally, if any of the comps are incompatible with high speed transfer, the router will automatically adjust.
N.B NEVER use WEP to secure, always use WPA-PSK 2 if possible
:0) x
Jun 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin mimo network card
So are you saying that it's not showing any network on the view available network screen? What is the message on the screen?
What is the model and brand of your wireless router from talk talk?
Its possible that we may need to check the wireless settings inside the wireless router. Provide me with it's model no. and I will look for a solution for you.
May 20, 2008 | Belkin High-Speed Mode Wireless G Notebook...
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Psp connection
the wep key is ur pass word that u made to protect ur wirless signal from hackers. u need to know the passsward.
Jan 14, 2008 | Belkin High-Speed Mode Wireless G Router 4...
Belkin (F5D5231-4) Router Logo
453 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
