Question about Linksys Ultra RangePlus Wireless Routr Router
Cannot connect to internet
I have linksys model wrt160n connected to my cable modem(optimum), I do not get an internet connection. If if I connect directly from pc to modem I do get a connection. I had a bad port on my modem so I replaced it with another one. Now is it possible that the ethernet port is bad on the router too.
  • valeriecook7 May 25, 2009
    Or rather I HAD the same problem!! This answer is spectacular. You were a huge huge huge help -- and got me out of the doghouse at that! :) Another Memorial Day miracle. Thanks again!!
  • 1,689 Answers
Best way to check if your ethernet is working (internet port) is by looping. get an ethernet cable, connect one end to either one of the local ports (1,2,3,4) at the back of the linksys router, the other end of that will then be connected to the Internet port or the WAN port. if the internet light goes on upfront, that will mean your internet port is working.
okay about making this work with your modem, it is still best if you start with ground zero on the router.
locate and press the reset button on the router for 20-25 seconds, then let it go, after so unplug the power, then plug it back in after 15 seconds.
once that is done follow these:
check your PC's IP.
click start>run>CMD> then click "OK"
on the command prompt type in ipconfig then press "enter"
click start(orb)>on start search type in CMD then press "enter"
if your IP address shows 192.168.1.xx (xx being a number from 2 to 253), you may close the window and proceed to the next step.
if your IP starts with 169.254.xx.xx please repeat resetting the device, then the power cycle.
okay so you got a good IP, follow these then. IE
2.on the address bar type then hit go will as you for a username and a password, leave the UN blank and the PW is admin, if that did not work try putting admin on both username and password.
when a linksys window shows up, you will see tabs like:
Applications and Gaming
on the "Setup" tab, look for a subtab that says "Mac Address Clone" then:
1. enable the clone service
2. click on the "clone your PCs MAC"
3. click on "Save Settings"
once saved, we do a power cycle including the modem.
1.turn the modem and the router off
2.after about 10 seconds, turn the mdoem and wait for the light infront of it to be stable. (like the "online" light should be solid)
3.once it is solid, turn the router back on, then let it sit there for about 15 seconds or modem until the power light is solid
once both devices are on, go back to your Linksys setup page, click on the status tab and you should be able to see an IP address on the internet section, once you have it, you're now online.
Posted on Jun 22, 2008
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
WAN connection problems with Linksys WRT160N
1.) Have you setup the router for use on cable modem?
2.) Run Your Setup utility that came on the CD for the router. And select Dynamic under the WAN settings unless you have a static IP address.
3.) If you do not have the CD to access the setup use IE Browser type Select WAN settings and then Dynamic from the list.
4.) Make sure your computers are using the router and not the cable modem. Reboot your PC's and verify they work if they don't open the internet connections and view the gateway is
Here is a link to the manual
Nov 26, 2009 | Linksys WRT160N Wireless Router
Changed my modem and now my wrt160n dosen't work
I recommend calling your ISP and have them synch your new cable modem with their connection. They may need to register the hardware address of your new modem for them to be able to recognize it and grant internet access.
Hope this helps.
Jun 25, 2009 | Linksys WRT160N Wireless Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
LInksys wrt160n v2 wireless router not connecting to internet
Most cable companies will only allow 1 active device at a time conneceted to the cable modem. When ever you change what is connected to the cable modem you must always cycle the power/reset your cable modem.
When you are reseting the units, always rset the cable modem first, wait until it boots back up then reset the router. If that doesn't fix the poblem then it may be a configuration problem.
I forgot to ask if you are cable or DSL.
Hope this helps
Apr 09, 2009 | Linksys WRT160N Wireless Router
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from to save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Linksys Ultra RangePlus Wireless Routr Router Logo
180 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
