Question about Vacuums
How do i get to my belt????? - Vacuums
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689123
Generic problem for all Vacuums
How do I get to?
Posted by amnharris99 on Jun 20, 2008
How do I get to my belt?????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Sorry…I would need to know more information as to what brand name & model # in order to let you know how and where to get to and change your belt. Usually the belt is changed from the bottom by removing screws r clips and then you can get @ the belt from the bottom or the top cover will come off in order to get to the belt. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 23, 2008
How to replace handy zip belt ?
Hello! Below are step by step instructions to replacing the belt on your hand vac. I have also included a link to the instruction manual which has pictures as well as instructions. Really hope this helps!
1. Lift the black plug on the face of the cleaner.
NOTE: BLACK PLUG MUST BE ON WHEN ATTACHMENTS ARE NOT IN USE.
2. Use belt lifter.
3. Center and raise the Hand Vac with your left hand as shown. Using your right hand, dip the belt lifter in and hook the belt around the lip of the belt lifter. Slip the belt onto the motor shaft until the belt lifter base meets the shaft.
4. To insure proper belt placement, gently turn belt lifter counterclockwise and remove. Make sure belt is pushed back on shaft.
NOTE: THE BELT WILL COME OFF IF NOT PROPERLY INSTALLED.
6. To remove the belt, hold belt lifter. Hook the belt on the left side of the motor shaft, turn clockwise and pull the belt towards you to release.
http://pim.ttifc.net/document/1239/
Jun 26, 2014 | Dirt Devil Classic M08100 Bagged Handheld...
How to change belt on dirt devil handy zip
2. Use belt lifter.
I need to replace the belt. Have the belt and the vacuum bottom off. What do I attach the belt too?
This unit has 2 belts. The V-belt on the brush usually doesn't cause problems. The larger flat belt requires regular replacement ( belt # 38528-035 ). The belt is first placed around the motor shaft toward the rear of the machine, and then around the large pulley. You must have strong fingers to stretch the belt over the drive pulley. Start the belt at the top of the pulley, and try to "roll " it around the pulley a little at a time, holding the belt firmly around the pulley as you go.
Feb 21, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I replace the drive belt in the hoover u6401?
Remove the plate from the vacuum's underside. You will see fourscrews or two clips that attach the plate to the vacuum. Removingthe plate will give you access to where the belts are running. Remove the old belts and replace with new belts. The hoover self-propelled models use two different belts. One is a flat belt Hoover #38528035 and the other is a V belt Hoover #38528034. You can find these belts at www.vacbelts.com on these pages:
http://www.vacbelts.com/hoover-38528035-belt.htm
http://www.vacbelts.com/hoover-38528034-belt.htm
Oct 14, 2009 | Hoover Vacuums
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
BELT TO THE BRUSH SEEMS TOO LOOSE EVEN WHEN REPLACED
Hoover U6437-900 U6439-900 Upright
LOOSE BELT. THE BELT IS STILL LOOSE EVEN AFTER REPLACING
The reason it seems like the belt is too big is probable correct, you may have the wrong size belt for your vacuum, use genuine belts – your particular model is a self propelled model and takes two (2) belts and they should stretch on very tightly and snug and it is smart to use the genuine belt package for the model that you have and we Recommended the belt change for flat belt(s) are 4 to 6 months for better cleaning
They should be tight on the belt pulleys in order to do the best cleaning – use genuine belts
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 03, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt slipping
on the roller/brush where the belt sits if that is scarred up or grooved out that will cause the belt to slip if you can fix roller try but i suggest new roller
Dec 02, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
