Question about HP Photosmart 8250 InkJet Printer
HP Photosmart C6100 All-in-one Series
Changed ink cartridges and error 0xc18a0001 will not go away no matter what I do. I have followed the instructions for unplugging and holding ok/cancel then plugging back in and it still doesn't work. 0XC18A0001
I want to print a 4 x 6 inch photo on the 4 x 6 inch photo paper but not using my memory card. I no longer have what I want on the memory card but I have a copy of the photo I want to print in a computer file. How can I get it to be pinted on the 4 x 6 paper rather than printing on an 8 1/2 x 11 page and having to cut it out.
Posted on Jul 12, 2008
The printer does an Error code 0xc18a0001 Ink failure and the computer doesn't seem to take the printer on I plug it in and out doesn't matter it's just like if I wouldn't plug in any new...
TO clear the error and return the printer to working order you will need to do an ink purge and reset. The problem is caused by air in the ink cartridges. This can happen if you use refilled cartridges or if you let the ink run to low and try to print something. Here is a link to an article that explains what has happened and how to solve the problem.
I hope this helps, if so please rate my solution.
Sep 23, 2011 | HP Photosmart C7180 All-In-One InkJet...
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart 8250All-in-One System Failure) I refer to printer documentation Error:0xc18a0001 Turn power off, then on again. I dId this command but...
Try taking out the cartridges, and turning off then unplugging the printer. Leave it unplugged for about five minutes, the plug it in. Wait a few more minutes, and turn it on. Wait for it to completely start up, then put the cartridges back in (make sure you are putting them in correctly, I think this is your product here). If it still shows the error, contact HP customer service. They will probably say something similar, though.
Jul 06, 2011 | Office Equipment & Supplies
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
What is printhead failure on my HP Photosmart C6100 series printer? and how can I fix it permanently?
The print-head is the "heart" of an ink-jet printer -- it pulls the ink from the ink-cartridges, and sprays the ink onto the paper.
If the "manufacturer-warranty" has expired, it is time to buy a new unit, and to responsibly recycle the old unit.
Jul 30, 2010 | HP Photosmart C6100 All-In-One Printer
Error message Oxc18a0301 on my hp photosmart c6150 printer
The "Oxc18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Jul 17, 2010 | HP Photosmart C6100 All-In-One Printer
Ink system failure error telling me to refer to printer documentation error 0xc18a006
The "Ink system failure" error is caused by air in the ink feed tubes, this happens if you use poorly filled cartridges or allow you cartridge to run all the way out. We have a step by step guide to purge the ink feed tubes posted on our web site at: This should get your printer back going in about 10 minutes.
I hope this helps, if so please rate our solution.
Corporate Computer
Jun 02, 2010 | HP Photosmart C6100 All-In-One Printer
HP PHOTOSMART C6100 All in One series ran out of yellow and for the first time since we bought it it did not give us the option to print in black only. Message says Ink System Failure...cannot print fax...
I called HP for troubleshooting assistance. My printer HP All- in-One is only 2 years old. They were very nice to run through a series of steps with me...only to tell me that "It is broken" and I will need to buy a new one. So that's my solution for today....Which leads me to the next question...Do I get another HP or something else??
Mar 22, 2009 | HP Photosmart C6100 All-In-One Printer
Hi ok you can try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 01, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart 8250 InkJet Printer Logo
604 people viewed this question
Ben Johnson
