Question about Brother Office Equipment & Supplies
Brother hl 4050cdn - the colour cartridges all run out together even though I've printed hardly any colour
  • Anonymous Mar 20, 2014
    BROTHER PRINTED HL-4050CDN
  • 120 Answers
The fluid component of the ink will evaporate if the printer is in a hot dry environment. Loss of ink over time should be anticipated.
Posted on Jun 27, 2008
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
The colours on our HL-4040CN have gone all strange - when we perform colour calibration the colours go either red or green. All toners are new and the drum has been replaced recently as well. We do a lot...
Hi
We need to isolated the problem on what cause ink cartridge not print in color. When even you installed new cartridges, It is necessary to run the print nozzle to clean the print head. Also, please try to clean the print head manually by removing all the ink cartridges and rub the print head into a white paper with alcohol until ink flows and then return it back and run the print nozzle for 2 times.
Then try to print again.
If it does not help you, please let me know to give you more help.
Mar 03, 2011 | Brother HL-4040CN Laser Printer
The cyan cartridge is leaking and is printing an intermitant line down the right side of the page
The cartridge needs to be replaced.
repairs to the cartridge are possible.
If there are any cartridge remanufacturing shops in your area
they will be able to repair the fault
Jan 25, 2011 | Brother HL-4050CDN Printer
My printer is not printing the colour yellow even though the cartidge is full and new
If you have run the nozzle cleaning utility, and you are not getting any yellow output, the cartridge is most likely defective. This also occurs if you are not using OEM ink cartridges.
Apr 25, 2009 | Brother DCP 115C All-In-One InkJet Printer
Are those papers printable on Brother HL-4050CDN ?
Hello !
If you want to print on canvas you need to use a plotter which use ink. An example is Roland or Epson. Personal i use Epson T5200 plotter and the result is awesome.
Apr 16, 2017 | Brother HL-4050CDN Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
Drum error : slide the green tab on drum unit in each colour?
you forgot to slide the tab, unless you do this you cannot use your printer im afraid, drum unit is a cylindrical part unit, unless otherewise you correct this instlltion procedure there is no othere way around it
cheers
Nov 25, 2008 | Brother HL-4050CDN Printer
I have just replaced the black toner as requested by my HL 4050CDN laser printer with a genuine brother replacement and now it's flashing on the LCD that I need to replace the 3 colours also. It's not...
just open the cartridge holders for the colours and even pull them out a little. Machine will think you replaced them.
Normally when you replace black it will ask if you did replace the colors. If you say no it will calculate the amount of toner in there still.
**** that is for next time. Now just open the cartridge holders for the collors and let the machine think you replaced them.
Apr 29, 2008 | Office Equipment & Supplies
117 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
