Question about Panasonic PT-61G54 61" Rear Projection Television
61'' Panasonic Projection TV
The TV switches between 16x9 and 4x3 when watching DVDs, is there any way to fix this? Or is the TV pretty much garbage? Also, if there is a way to fix it, is it an inexpensive fix?
    Sergeant:
  • 280 Answers
If you have a HDMI cable from the DVD to the TV , The TV will automatically go to the 16.9 aspect ratio. For HD. When you are on tuner the set falls back to your default setting. If you don't want the set to go to 16.9 automatically use RCA type cables to connect your DVD
Posted on Jun 20, 2008
My Panasonic multimedia projection tv -PT-61LCX65 needs a new lamp....where is the bulb located within the tv? How do I remove?
Hello, the lamp is located at the rear of the set. Unplug the tv before you start. There is a door secured by a screw, remove it to expose the lamp housing. There is a screw that secures the lamp, remove it, then you can gently grasp the handle and slowly pull it towards the rear of the set. To replace the lamp, gently slide the new lamp back in and secure it with the screw you pulled out. replace the lamp door cover, and replace the screw. plug the tv back in and turn it on, you should be fixed. Here's a link to a video on how to do it....https://www.youtube.com/watch?v=xvF36pepCOI.....tks
Jul 04, 2014 | Panasonic PT-61LCX65 61" Rear Projection...
I have a cracked screen and im wondering how to go about fixing it
Replacing the screen on a 61 Inch TV is a serious and expensive process, My suggestion is look for a cheaper TV, possibly a plasma or LCD with HD. They are pretty cheap now and save tons of space compared to the rear projection TVs.
Mar 14, 2011 | Samsung HLP6163W 61" Rear Projection...
I have a green spot in the upper left corner when watching tv . Is there a repair for this problem?
The spots are caused by errors in the eeprom affecting the optical engine data. The fix is easy but it will have to be done by an authorized Panasonic shop. Call your toll free customer line at panasonic to find out, but I'm sure the repair should be covered under warranty regardless of the age of the unit. Thx
Bill W.
integrityhomeworx.com
Mar 07, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Lamp light flashes twice , what do i do ?
Tv "LAMP" LED light indication on or blinking is it dead.Tv have not change the projection lamp like 1 1/2 or 2 years and tv been on and watches like 4 or 5 hours a daily?Yes,the tv require a new prjection lamp.
Jan 24, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I have a 61 inch panasonic DLP TV the power light blinks 2 or 3 times (not at home to check) and the power gores off. We were watching tv herd a small pop and the TV shut off. What is the issue and is it...
Hi, my name is John. Welcome to FixYa. Yes its easy fix. What you heard pop was a capacitor. Let me know if I can help you........Thanks for choosing FixYa...John
Dec 03, 2010 | Panasonic PT-61DLX75 61" HDTV
Pt61g42v.this is a panasonic 61 FOCUS OUT
my tv flat lined the screen went black with a twisted line across the screen what is the problem?
May 13, 2010 | Televison & Video
my panasonic model PT61G42V screen went flat lined and went blank still has sound, wwhat should i do?
Mar 22, 2010 | Panasonic Televison & Video
Color spots on 61" LCD Panasonic rear projection tv
had the same problem on my 52" LCD rear-projection Panasonic,
contacted Panasonic support (number is on their website) and after
several transferred calls, they set up a service call with an area
service rep, who callled the house that evening to confirm appointment.
He came to the house, removed the set back cover, and installed an
EEPROM upgrade, problem is fixed and was told problem will not re-occur.
No cost due to Panasonic extending the warranty to fix known issue with
sets. (Mine was over 3 years old).
Mar 11, 2008 | Televison & Video
Panasonic PT-61G54 61" Rear Projection Television Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
