Question about Toshiba 43H70 43" Rear Projection Television
I want to remove the picture tube of a projection t.v. console lx1-sears
Blown out by an electrical surge ,I was told by Sears not to repair it,as it would cost $2000.and next year it is obsolete, totally.Gio
    Sergeant:
  • 280 Answers
There are three picture tubes in a projection set.
Remove the front screen and you can see the 3 lenses. There is a steel frame they are mounted to and you will see bolts around that frame. remove all the bolts and lift the complete assm. up. Disconnect all wires to the yoaks and picture tubes and lift the tubes and lenses out. then you can separate the tubs from the lenses.. be carefull as there is a coolant between the projo lenses and the tubes. this stuff is messy so don't do it on you front room carpet. If you get the coolant on you was it off with Windex
Posted on Jun 20, 2008
TV has red lines and showing double the picture. One Sears tech suggested may have to replace bulb for $500???
yes thats a good price to replace a bad red picture tube and at the same time the convergence ic , this is for the doble picture and lines
Apr 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv picture blurry, not clear
The LXI or Sears brand used philips TV's. These sets are known for bad coolant fluid. In between the picture tube and their lenses is a layer of clear coolant. Over time the coolant breaks down and causes the picture to become blurry. This can be a complicated repair involving removal of the picture tubes and lenses. Have a repair shop check it for you. Thanks for using fixya.
Dec 12, 2009 | Televison & Video
Sony KP-51WS510 51 in. Rear Projection Keeps blinking 5 times. The red and green projectors are working fine, but the blue is not working. Sears service replaced the power supply, and the first board, then...
You may want to recheck your connections coming off the blue tube to the board. Also check the IC links/Pico fuses on the power board. I have a repair manual for this Tv if you need it. shanesebay304@yahoo.com
Dec 10, 2009 | Sony KP-51WS510 51" Rear Projection...
Ps3 has black screen with white lines some noises
I am sorry but the voltage surge, which must have occured after having switched off the protector has most probably blown or fried the High Voltage circuitry which makes the tube function. It could be that both horizontal & vertical control IC's are damaged. If the picture tube is still OK then its worth repairing. However if the picture tube is gone then better to buy a new diplay unit after checking up the rest of the equipment that a playstation consists off......................................sodeep
Aug 09, 2009 | Sony Video Game Consoles & Games
Sears typewriter needs repair (keys won't move)
Check your local phonebood for typewriter repair shops. The typewriter you have iwas manufactured by Smith-Corona for Sears.
Aug 08, 2009 | Office Equipment & Supplies
1998 Sears 626.5538 Television color issues???
You either have one of two problems the first is bad picture tubes or circuitry to drive them, At this age it time to get a new TV; Both repairs are not cost effient.
Dec 18, 2008 | Televison & Video
I had a new sears heating unit installed by sears contractors yesterday. Before I purchased the boiler, I was told by sears salesman that I had a maintenance plan that included 24/7 repairs. 6 hours after...
Yes as with all big companies problems with comunications are a pain to say the least. Anyway it sounds like someone left a loose fitting. If you can locate the place where it is leaking there is probably a fitting loose there which you can tighten up with a couple of wrenches.
Sep 27, 2008 | Heating & Cooling
60P8341A 60 in. Phillips TV
I had the same problem, I had a repair man to come out n he told me what the problem wasn that it will cost around $300.00. So i took it apon myself n removed the keyboard behind where the power buttons are. I waited 10 minutes and replaced it then I had no problems for3 years. Now that its started back up i need to replace it, but they don't sale the part n e more. But I found a substitue part on Sears direct parts n the part number is RFR-PTS-28 they look different but work the same. Right now the price is $28.00.
Apr 30, 2008 | Philips 60P8341 60" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
207 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
