Intel Motherboard Logo
Posted on Nov 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have one computer with E210882 intel motherboard..i was open this computer for replace the harddisk i connect one used hard disk now this computer is working but the audiosystem is not working picture also have problem how can i fix this problem there is need any software installing..?my system informations is below please replyme as soon as posible thankyou..OS Name Microsoft Windows XP Professional Version 5.1.2600 Service Pack 3 Build 2600 OS Manufacturer Microsoft Corporation System Name SW-B702ABDDDDA4 System Manufacturer ATI___ System Model AWRDACPI System Type X86-based PC Processor x86 Family 15 Model 4 Stepping 1 GenuineIntel ~3000 Mhz BIOS Version/Date Award BIOS for Intel GC11010N.86A.0303.2005.1108.2057, 11/8/2005 SMBIOS Version 2.3 Windows Directory C:\WINDOWS System Directory C:\WINDOWS\system32 Boot Device \Device\HarddiskVolume2 Locale Qatar Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)" Time Zone Arab Standard Time Total Physical Memory 512.00 MB Available Physical Memory 81.19 MB Total Virtual Memory 2.00 GB Available Virtual Memory 1.96 GB Page File Space 1.11 GB Page File C:\pagefile.sys
Steve Allison
Level 3:
  • Master 5,569 Answers
  • Posted on Nov 18, 2010
Steve Allison
Master
Level 3:
Answers
5569
Questions
Helped
2002247
Points
16452
> used hard disk
If you have installed a drive from another system, it probably has settings applicable to the system from which it was removed. The original system could well have had settings for a different audio chip and video resolution. You need to look at the device drivers for audio and video and make the changes needed so they apply to the laptop you have.
2helpful
Intel E210882 Motherboard can't ON
> Check the power connection to your computer in good condition.
> Remove the SW on the motherboard connection and switch on the computer by using the SW pin tespen to affect positively and negatively. (To make sure the button on / off function)
If your computer can be turned on this means that the button on / off there is a problem but if the contrary, create a test on your computer power supply box in a manner which was troubleshooting with the power supply box which is still functioning properly or even better one.(Problems on the motherboard can also cause your computer can not be turned on)
If you have to do some tests and the problem is not coming from your motherboard, I believe there is no problem for your computer is switched on and used as usual.
My Mother Board Intel. My Hard disk is not
May be ur system doesnot support the harddisk. Go to BIOS settings in the Advanced option see if the hard disk is detected or not, if not then check the connections of the hard disk and then go to boot priority and change first boot device to cdrom and then try
Harddisk doesn't appear in the list of intel
The computer is not getting pass the POST (power on self test) and therefore the hard disk information doesn't appear and the computer won't boot up.
The problem is with your RAM modules, your motherboard uses interleaved memory, it requires two identical RAM modules (a pair of RAM modules) to be inserted into the motherboard memory slots. These slots are color coded and the RAM modules MUST be inserted into the RAM slots with the same color.
2answers
It wont rocognise the hard disk but will pick up everything eslse
Change ide or sata cable.
Also change power cable of smps to harddisk.
Make sure your harddisk set as master with jumper settings.
Read jumper settings on harddisk then set harddisk as master.
Then check in bios.
Change ide or sata ports on motherbord then check.
Hi. Pls help me . i have intel motherboard n232,E210882 model. I hang one problem of computer not boot. kindly tell me how reset or reboot the program.
booting means checkin hard disk while start up............
if ur system cant boot up then it might be problem of ur hard disk or the connections of that........kindly check the connnections and once service ur hard disk
1helpful
2answers
How much Hard disk my motherboard D845GVSR will support.
There's not really a limit to how big a harddisk you can support. The only thing that can restrict you is the connection, because, for obvious reasons, you can't connect a SATA disk to an old IDE board, but it seems like you're aware of that.
You can just buy any SATA HDD you want!
Regarding hard disk updation
you need to buy a new harddisk with much more capacity.but for the drivers, it can be downloaded
2answers
HARD DISK IS NOT DETECTED
check the data cable and power cable connectors of the harddisk, otherwise the hard disk check on other computer.
DISK BOOT FAILURE
The sata cable\bus that connect the hard disk with the motherboard get loosen up some times. that results in the disk boot failure. if you once remove the sata cable from the harddisk and motherboard and then fix it tightly you can get the system working properly again. if the problem again persist then bye a new sata cable and fix it by replacing the older one, Thank You!
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
