I hooked a extra phone line in my 360 and hooked the other end to the back of my modem and it's not working.
  • 105 Answers
Use single line to your pc only remove the line to use your 360
Posted on Jun 20, 2008
Trying to hook up my xbox to the internet, I moved everything out of the spare bedroom to the living room. problem is the nearest phone jack to hook up the cable to the modem is in the kitchen, or do I...
Hello noah757702
In order to connect to Xbox 360 your modem would need both cable and phone jack, first ethernet cable connected from Xbox 360 to the modem and modem in turn should be connected to the phone jack to complete the connectivity set up, let me know if you need more info on this
Nov 17, 2009 | Video Game Consoles & Games
Trying to hook up xbox360 to my internet to play online
if your using a modem its possible that it doesnt have a Ethernet port....Check the back of your modem and you should see a port that says ethernet near it. Plug your ethernet cable to the port in the back of the modem where it says ethernet. With the other end you plug it into the back of your Xbox 360 (its located in back to the far left....it looks like a phone line jack). You should then have xbox live
Jun 13, 2009 | Microsoft Xbox 360 Console
I get a dial tone and can use the phone, but it doesn't ring.
Check to make sure your ringer is turned on on your phone. Did you try another phone?
Mar 12, 2009 | RCA MODEM CBL (PC3060)
Bridge computer to grandstream (for phone power)
I have the same problem Did you get an answer. Verizon wants I should talk to there expertise tech for a fee. Did anyone try it?
Jan 31, 2009 | Lands Phones
VoIP Modem Problems??
the line coming in from your old provider of phone is causing your problem, I am a phone tech for cable company and I find this all the time . your old phone provider if still hooked uo is push a small amount of voltage onto your in house wireing even though it does not have dial tone. just unhook your test port on the old interface and this should fix your problem .dsl filters will also cause a prblem , make sure all filters are removed.
Jan 22, 2009 | Computers & Internet
I have a Lexmark 5150 all in one.I recently hooked up to broadband.I cannot use the fax now. It says no communciation. How do I get my fax machine to work again? The printer and scanner work fine.Do I have...
Hi Brenda,
Your All In One wants a phone line hooked directly to it. It won't fax without a "POTS" line directly hooked to it. POTS stands for "Plain Old Telephone Service" which is the line with good old dial tone on it.
Dec 17, 2008 | Lexmark Computers & Internet
DCT 646
If you have a phone that works off a broadband modem, that is a VoIP phone. That will not work with a home phone line. I'm assuming Verizon is your local Telephone carrier that provides your local dial tone.
The broadband modem would have the phone number of whatever VoIP phone service you have.
Dec 16, 2008 | Uniden DCT646-2 Cordless Phone
Caller ID doesn't display and phone rings 1 time then stops
The Uniden TRU9XXX series has a high level of handset compatibility between bases. Depending on the handsets you bought to go with your 9480, you may be able to buy another model in the series and use the old handsets with the new model. Alternatively, you could buy another 9480 here (the -2 on the end of your model number just means that it came with an extra handset).
Before you do that, though, it might pay to hook up a regular (corded) caller ID-enabled phone to the line and see what happens there when you call. If it works properly, go buy your new phone. However, if you see the same behavior there as with the Uniden, chances are that the problem is not with the phones. Possible other causes could include a fax machine, modem, or other device in-line with the phone; a defective piece of equipment hooked up elsewhere in your house; etc. If nothing obvious applies, you might want to give the phone company another call--just because they couldn't find a problem on their end doesn't mean one doesn't exist.
Jan 07, 2008 | Uniden TRU9480 Cordless Telephone
Telephone dont work
That light is indicating that you have a phone off the hook, a short in one of your phone lines, or a bad modem. Unplug the phone line from the back of the modem. If it stays solid, plug it back in and go and disconnect every phone in your house. If it stays solid you have a phone issue. Plug them back in one-by-one and see which one causes it to start blinking. If it doesn't go away after unplugging all your phones, you have a phone line issue. If it is still blinking after unplugging the phone line from your modem, your modem is bad.
Dec 30, 2007 | Arris Touchstone 450a (CM450) Modem
Medicom phone No dial tone
1podinker, you have a phone off the hook or a bad phone line. Plug a phone into the back of the modem and see if it works.
Bamachicky, need more info on what your modem lights are doing.
Dec 18, 2007 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
