Question about HP Business Notebook 530
Electric light flashing
I have hp530.after charging my laptop,when disconnecting from power the light that switch on when the battery is low keep on flashing.
please help me
  • Anonymous Sep 06, 2008
    I HAVE THE SAME PROBLEM. I HAVE ONLY HAD PC A FEW MONTHS SO SURELY BATTERY HAS NOT GONE ALREADY
  • naura Dec 26, 2008
    I have the same problem; when my notebook isn't connected to the ac
    supply, the amber light starts blinking continuously and it won't turn
    on. I have to plug it; otherwise, I cannot use the notebook. I've only had my notebook for A MONTH, can the battery be SO bad that it's already useless??? Please
    help!!!!!!!!
    Genius:
  • 2,028 Answers
This indicates that your battery isn't functioning properly or is going bad. You need to replace the battery. Bateries are batteries, some are better than others and some wear out faster than others, even though they may be the same brand, eventually all batteries need replacing.
Posted on Jun 20, 2008
I HAVE A IBM THINK PAD MODEL T 42 AND ALL OF THE SUDDEN THE LIGHT KEEPS FLASHING LOW BATTERY AND I KEEP IT PLUGED IN AND THE BATTERY DOES NOT CHARGE
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Oct 16, 2010 | Computers & Internet
Subaru legacy power lose when switched off. new battery charge rate 14 volt+
The charge rate of 14 volt shows that your alternator is responding as it should and is doing its best to recharge the battery. Even with a fully charged battery if you switch on the power hungry electrical items (main headlights, rear window demist heater etc) you should see the alternator respond by pushing out 14+ volts. A low battery will show about 12.2 volts when disconnected. OK you need to find what is draining your battery when the car is switched off. With the car off disconnect the negative terminal and measure the current flowing between the disconnected cable and the negative terminal, it should very very low, just enough to keep the clock running. If you do have residual current flow, remove and return each fuse one at a time and note each time the current reading. Quite quickly you will be able to isolate the circuit that is causing the drain. Often it is a lighting circuit for an interior light that you cannot see....such as a glove box light not going off when the lid closes or the trunk light staying on. These work by a contact switch being opened by coming into contact with a bracket when shut. If for some reason the bracket gets bent or is dislodged then the light stays on.
Jun 01, 2010 | 1992 Subaru Legacy
Shoprider nippy powerchair when i switch it on lights on control flash and it keeps beeping
Here are some ideas :- Is the charger disconnected from the chair, are the brake levers in the drive possition. do the batteries need charging. Failling that it could be a controler fauld so you will need to consult an engineer.
Apr 30, 2010 | Electric Mobility Shoprider Electric Power...
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
Hp530 turn off suddenly
Get a power charging adaptor from HP (if a smart adaptor) or a generic anywhere that matches your spec. Your device is doing what mine did, but in addition mine beeped softly as a warning of failure. Being a smart adaptor, I had to order one from HP, a generic won't work.
Sep 05, 2009 | HP 530 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
If the computer is running on a battery, the about41.jpg light operates as follows:
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Laptop intermittently charges / works
Seems the power board is defective, you need to take this laptop to a service center to check for a new power board or if diy check ebay, you can find a good one there.
Jul 08, 2009 | HP 530 Notebook PC
My battery won't charge - Toshiba P100-188 laptop
AHA!!! You are lucky for I just diagnosed that same problem for a friend of mine. Would it surprise you if I told you it was the cord? true the pc work when connected but charging and powering are two different things, and technically its not the cord but the box thats in the middle, sorry to inform you that they do not sell that part separately and its not cheap either, Your best choice would to be buy a universal one which is what I did for about $30 compared to $60-$90 are the real one :-( Anyway Hope this was helpful
Good Luck =)
Jun 05, 2009 | Computers & Internet
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
HP Business Notebook 530 Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
