Question about LG WD-1280FHD Front Load Washer
LG WD-1021-WF Front Loader Washing Mashing
I need info on how to replace the door rubber seal.
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Posted on Nov 23, 2008
Posted on Nov 09, 2010
  • 489 Answers
Replacing the door seal is not an easy task.  You will need to get 2 special tools from LG to make it as easy as possible.  The spring loaded clamps are very hard to put on because the springs are so strong.  Once you get the special tools, remove the front clamp off the door seal.  Pull the seal off the lip to gain access to inner seal clamp.  Remove the inner clamp and pull off the rubber door seal.  Just reverse the procedure when reinstalling the new seal.
Posted on Jun 26, 2008
I am a novice. How do you replace the outer seal on the main large drive wheel, please
what maker of machine and model
there is a lot to undo to get it right
on a front loader I cant find a step by step
how to diy for a front seal renewal
watch this youtube if not clear for you ..its an LG front loader
ring a washing machine repairer
Washer Leaking Water LG Front Load Washer Door Boot Seal Replacement part...
Sep 22, 2016 | Washing Machines
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
LG WD1433RD Washing comes out with black lines and sometimes even worse Have cleaned rubber seal repeatedly Same problem for years every few washes
My LG Front Loader Washing Machine WD-1433RD having a leakage from Front when it fills the water up to ~70% of water. There is no leakage prior to that level. Please help me to fix this.
Feb 19, 2011 | LG WD14311RD Front Load Washer / Dryer
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
I have a two month old Samsung WF350 front load washer. I have a trickle of water leaking from the bottom of the door during wash cycles.
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
Jun 26, 2010 | Samsung Washing Machines
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Feb 28, 2008 | Washing Machines
LG WD-1280FHD Front Load Washer Logo
1,068 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
