Question about Creda W100FW Front Load Washer
Electrical specs I inherited a Creda front loading washer, model #17064ecwa242 30156956 with a European plug. Can you tell me how to change this to a US plug. Also, is this a 110 or 220 volt washer?
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Posted on Jun 27, 2009
just changed the bearings on my creda simplicity 1000 w100fw
rebuilt it water going in and out ok, now the washing cycle does not work,plenty clicking noises, any IDEA.
many thanks, John
Posted on Jul 03, 2009
My Creda simplicity 1000 washing machine wasn't draining or spinning now there's no power light coming on and does nothing when i turn it on is it un repairable
It could be a lot of different things. Maybe the timer. If you know someone who has a volt meter and knows how to use it. Find you machine with a Google search, look for trouble shoot washing machine timer. That's the way I would do it. You want to look for a open in the electrical system *{the switch} like a broken wire inside the switch. Make sure to unplug the machine first. You won't need the power on for the first tests. A volt meter can be purchased for under $10. and any home repair store or box store.
Dec 14, 2014 | Creda W100FW Front Load Washer
Creda tech came out, can he tell if machine belt is broke by just listening and turning the drum.
An experienced engineer would able to tell if belt is off, or if the main drum bearings were going, simply by spinning the drum by hand.
Feb 20, 2010 | Creda W100FW Front Load Washer
Creda W200FW No: 45177606 washing machine have removed the PCB from a Creda W200FW washing machine and lost the info as to which plug goes where. Some are keyed and will only go on one place but some will...
Hi
I will try to help as best I can
  1. double red plug onto1x2 2
  2. double black wire plug onto 1x9 2
  3. blue black wire plug onto 1x11 2
  4. then 6 wire plug onto 1x5 6
This hopefully will solve your problem.
Thanks.
Nov 11, 2009 | Creda W100FW Front Load Washer
Hi.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Neptune front load washer
if i remember correctly usa is 60 cycles and european is 50 ..might be wrong but don't think it's possible without a lot of changes ..best get an adaptor if available..this should plug into foreign outlet and then plug washer into it
Jun 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
62 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
