Home networking I have Verizon wireless, I want to add my older laptop to the network. It's an hp notebook n5170 running Windows ME. I purchased a Belkin Wireless G USB Network adapter. After installing software, it says I'm connected however cannot get to the internet. Any ideas? Thanks
    Guru:
  • 377 Answers
Hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
  10. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it shHome networking - 34b0a7b.jpg/li>
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Posted on Jun 28, 2008
  • 120 Answers
What are the specifics of your network? Do you have a wireless router?
Are you attempting to connect wirelessly to another computer that is connected to the internet? If so, you may need to bridge the connections on the computer "in the middle".
I would really need more info to go on to assist.
Posted on Jun 27, 2008
I purchase hp laser m1005, can i convert to wireless
Not that I am aware of , but to print from it wirelessly can be done if you have a home network. If you have a Destop computer ,for instance, you could connect via a printer cable to the desktop and share the printer on your home network you set up. on your laptop just add a printer and it will work wirelessly as a network printer.
Nov 09, 2012 | HP LaserJet M1005 Printer
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
I have a Toshiba satellite A65-S1068 and I want to add the wireless connection to it in my network connection is that possible
FIRST YOU WILL NEED AN INTERNET PROVIDER. THAT CAN BE AN USB MODEM (ATT,VERIZON,T-MOBILE).WHEN YOU PURCHASE THE PRODUCT IT COMES WITH A CD SOFTWARE TO MAKE YOUR CONNECTION
IF YOU HAVE YOUR PROVIDER
GO TO
1-CONTROL PANEL
2-NETWORK CONNECTION
3-CONNECTION WIZARD
Oct 12, 2010 | Toshiba Satellite A65-S1068 Notebook
I can not figure out how to get the computer to make a wireless connection.
Add the Home SSID to the Preferred Network List After you set the SSID on your home gateway, you may need to add it to your preferred network list if Windows XP Wireless Auto Configuration is enabled. (Although automatic configuration is nice to have, your IT department may have disabled it on your laptop in order to meet their needs. If they have, you'll need to use the tool provided by your laptop or wireless manufacturer to manually configure wireless settings.) To manually add your home wireless network to the list of preferred networks when Wireless Auto Configuration is enabled, follow these steps:
• In Control Panel, click Network and Internet Connections, and then click Network Connections.
• Right-click the Wireless Network Connection, and then click Properties.
• On the Wireless Networks tab, shown in Figure 3, click Add.
Figure 3
• In the Wireless network properties dialog box, shown in Figure 4, enter the SSID you configured for your wireless gateway (ExampleHome_g in this example.)
Figure 4
Note: Figure 4 assumes you've added the Windows WPA Client Update. If you haven't downloaded and installed it, you probably should. For more on the WPA Client Update, see Overview of the WPA Wireless Security Update in Window XP.
• Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway.
• Click OK and your home network will be added to the list of preferred networks.
Now, whenever you're at home, your work laptop should automatically see your home wireless network and connect to it.
Jul 05, 2010 | Acer Aspire 5100 Notebook
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\192.168.0.50printer shared name where 192.168.0.50 is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
Wireless problem with laptop, HP DV9000
Follow the link below, read about this problem, and then call the special HP phone number. They are repairing these computers under a special enhanced warranty policy, even if the regular warranty is expired. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
Dec 27, 2008 | HP Pavilion dv9000z Notebook
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Sony vaio PCG CIXD picturebook laptop
You should be able to use any usb wireless network adapter, or any cardbus type II wireless adapter. BUT if you are running windows 98 or ME or an older version than xp... before you purchase one, go to the manufacturer site and be sure that there are drivers for the version of windows that you are running. Here is what to look for and a link to some items that may work.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833129133
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124280
Mar 30, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
