Yamaha RX-V757 I have speakers wired throughout the house into a connection box which is operated through Zone 2. The circuit breaker tripped and I rest but Zone 2 won't work. When I tried to adjust Zone 2 volume, the receiver displays "FIX".
  • DRDOWD01085 Jun 23, 2008
    The system had been operating for 5 years without a problem. The circiut breaker tripped and I reset but Zone 2 will not function. When I tried to adjust the Zone 2 volume, the receiver displays "FIX".
  • Anonymous Aug 31, 2008
    I have had the same issue. When I tried the fix list above.by using the remote, I was unable to get to manual set up
  • 151 Answers
Make sure you have not wired from box to speaker then to another speaker ,you should wire from switch box to one speaker then from box to another speaker, this presents the right load to the amp, if you have done this you may have a faulty switch box.
hope this helps.
cable guy.
Posted on Jun 20, 2008
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
Mar 14, 2014 | Audio Players & Recorders
Subwoofer output issue 5.1 setup. 2 speakers
Try turning up the sub out-put, in the Receiver settings
Sep 11, 2013 | Yamaha RX-V757 Receiver
Just bought yamaha rx-v467 reciever, it worked for 2 mins then it trips out, wired all surround sound correctly. now unit only turns on for 2 secs then turns off. it does it 3 times and then you have to...
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 09, 2010 | Yamaha RX-V463 Receiver
Can a yamaha ipod dock connect to an rx-v757 receiver?
You can connect him true the auxiliary inputs with an adaptor cable 3.5mm to rca
Jun 02, 2010 | Yamaha RX-V757 Receiver
Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Jan 12, 2010 | Yamaha RX-V757 Receiver
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
i thinck that you have internal short circuit in wiring of zone 2. and you must fix this wiring first befor you go ahead -or you disable it by disconnecting it-and the rest of the system will work fine.
Jul 26, 2008 | Audio Players & Recorders
Yamaha RX-V800 Zone 2 Operation
yes it works great. hook them up to zone B. then below the power button is a A/B button. select button B and then zone B will work.
heres the manual if it helps
Apr 02, 2008 | Yamaha RX-V800 Receiver
135 people viewed this question
 Grubhead
Grubhead
