Question about HP Officejet 5610 All-In-One InkJet Printer
Error Code problem
Keep getting error code when i try to print or copy. not allowing me to do any of these things. error code 0xd0620230 Reset Power
  • 26 Answers
My mother's printer had a similar problem, I was able to find this solution on the HP site.
Disconnect the USB cable from the back of the printer, but leave the printer turned on.
Open the cover of the printer and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the printer and wait for one minute.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
I hope this helps you too...
Posted on Jun 25, 2008
Error C3102
The Fuser is not turning... follow these steps
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, wait 10 seconds and turn the machine back on, this should reset the service code and with any luck the machine will run!
May 03, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Canon pixma MP600, error code 5010, what does it mean ? Can not turn the printer on for any other purpose, no scanning, copying or printing.
There are a few things you can try:
  1. Power reset; press and hold the Power button until it the machine starts a diagnostic mode; if this doesn't turn on the machine, unplug it for 10 minutes and upon plugging it back in, see if the error reset itself
  2. Unplug all USB devices (including the printer) and reboot the computer. Once the computer has rebooted, plug in the printer, allow it to install (it should install automatically) and see if the error is corrected. Sometimes there can be a temporary conflict and the only way to solve it is to remove all other USB devices (this can work for external hard drives too).
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Nov 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Getting error 0xd0620230. Could you help
I managed to track down some information that may be able to help you. Power off your printer, then press &hold buttons while powering on. If it doesnt reset then unplug it & press & hold buttons while plugging it in.
# & 3 Partial reset
# & 6 Semi full reset
# & 9 Full reset
A full reset will clear any stored information in th printer, speed dials ect. So always start with a partial reset and work your way up.
I hope this helps.
Nov 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 5610 Error 0xd0620230
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab88
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Dear team, how to solve the error code 0xd0620230 reset power model :- hp pfficejet 5610 all-in-one
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | Office Equipment & Supplies
Officejet power reset error code
I have a error code that is 0xd05d010d I have tried reinstallin g drivers and software didnt work. tried unpluging power cable and holding ok and cancle buttons and plugging back in didnt work. now Im not sure what to do can you help please.
Jul 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Error code on 5300 printer
turn off the printer
unplug the power chord at the back of the printer
wait for 5-10 sec.
replug power chord
turn on the printer
Jun 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 0xd0620230
hhhmmm try to download a resstter for your printer model, cause that error code cud mean that some part of your printer has reach its limits, printers nowadays have a counter in it. if you cant find any resetter software for your printer you shoukd call the HP tech. support cause they are the only who knows the right key combination on your printer panel that allows the parts to be reset.
Aug 21, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
173 people viewed this question
Seeker5211
Seeker5211
