If it is getting hanged often then it can be due to some part being loose. like the CD drive is not connected properly. or the lan card is not connected properly
if any of the devices are not connected properly system tries to update and hence gets hanged
Have you been into the setup screens and seen what standby modes are offered. They are now normally listed as S1&S3, S5.
Which Standby mode is set now in your bios settings?
The ability to recover from Standy or Hibernate mode is quite dependent on your system's Power Supply. It is very possible that this is not functioning correctly. Would you be willing to accept that as an answer?
Regards,
Worldvet
I have done house calls for Dell a lot.
I think you should follow up with them and I would ask for a supervisor. Then insist on a replacement.
They usually respond to this type of request by asking you to allow them to send a tech. The tech will usually arrive with a new motherboard and probably in your case a new power supply as well.
Regards,
Worldvet
Try setting your CMOS/BIOS to default and not optimize. Alternately, reset your CMOS/BIOS using the jumper on the motherboard or removing the battery for a few minutes. Thereafter on POST, configure only the date/time and leave everything else to default settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Use memtest to test your ram
http://www.memtest.org/
before requesting more assitance please leave comments I can help you.
start with testing the memory and report back with results.
also make sure you have all the updates includeing the service packs from www.windowsupdate.com
this information may be usefull to you
http://support.microsoft.com/kb/826959
You better reformat your desktop,maybe virus infected allready,it happens of my PC before virus infected, desame of problem yours hung ups ,intermittent ,its going works only when turns off and turn on again hungs again ,,when i going to reformat its okey again..try this option..
Computer stops functioning. Whatever was on the screen at the time of
the lockup remains there, and the computer does not respond to any
input from keyboard or mouse.
Unfortunately, you can’t do anything
to prevent a system lockup after one has already happened. The only
remedy is a reboot (restart the computer). You can try restarting the
computer by pressing the CTRL-ALT-DELETE key combination. If that
doesn’t work, hold down the computer’s power button until the machine
shuts off, and then give it a full 10 seconds of rest before starting
it again.
Restarting your computer may resolve the issue that
created the lockup. Try once again to complete the task you were
attempting at the time of the lockup. If your system freezes once
again, you'll need to begin systematically diagnosing the problem.
a limited amount of memory and processing power. Any attempt you make
to push your computer beyond those limits will probably end in a
lockup.
what the video card you are using right now..?
"Certain Intel Dual and Quad Core processors may generate machine
check errors or cause the system to hang. Dell has developed and
released BIOS updates for all affected systems to resolve this issue." - Dell - Support
Download and Install the Updated BIOS Version
Regards,
micro
Let me know if you need more info/assistance about this...
Thank you..
Try to use 1 ram first then try the other one maybe ram is not suitable with your motherboard or each other
I removed 1 GB of ram and no help.
The command to come out of hibernate or stand-by is recognized in that the fan comes on but nothing else seems to happen.
I have already formatted and no help
The computer is new, but Dell has not been able to solve the problem. I have downloaded all updates and latest drivers including bios.
I have the latest BIOS update.
Everything is tight.
