Hello i am trying to copy a disc but it keeps on cuming up with internal error ,than when i done it again it come up with internal error 275 and it freezes,any ideas please.
  • 105 Answers
Some disk is write protected try use Nero Burning rom
Posted on Jun 20, 2008
Source Drive read disk error
The Cd you are trying to copy may be damaged, take it out clean it and try again, if that doesn't work check that the media you are trying to copy is compatible with the source discs, wouldn't be the first person to try copying a CD onto DVDs or vice versa, an easy mistake i've done this myself
Feb 09, 2013 | Acard Technology (ARS-2030LD) DVD±RW...
Nuvi 200 'Updating GPS Firmware 1%' Problem
there is actually a problem lots of people have with this unit and it seems in the FAQ i can find through garmin that it can take up to 30 minutes to aquire the satellites. there is no fix but if it has the option to get a additional antenna i would try so. If not id suggest a new unit.
Jun 18, 2008 | Garmin nuvi 350 GPS Receiver
Error message when copying blueray to my hard drive
Hello and thank you for your question,
This error is usually caused when tryed to rip or burn from a drive that does not support the Blue ray format. If your drive does then please contact Microsoft here to assist you.
Link: http://support.microsoft.com/
Please remember to rate this answer for your ratings help me better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all your technological needs please continue to use fixya.com where you will find the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Guru: zdeuyo
Mar 28, 2011 | dvdfab.com
Hello, My Panasonic SA-HT740 will not play standard copyrighted DVD's any longer, but it will play all burned or copied discs. How do I get it to play standard copyrighted DVD's again?
Are you getting a region code error notice on screen. If so you are having a region mismatch between the system and the disc. When you burn your own disc the copying software first removes the region code and copy protection tags.In other words your copy is region free and will play in any machine.
Mar 08, 2011 | Televison & Video
Hello! I get the error message when I load up 3.55 from USB. 8002F281 what's wrong? Best reagard Per Gustafsson
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual
There may be dirt or scratches on the disc or internal lens.
First remove the disc and gently wipe from the center to the outside with a soft cloth. You can also try using the Lens Cleaning Kit (sold separately) to clean the internal lens. Then re-insert the disc in the console and turn the power on again. If the same error message still appears, use this repair guide...it helps a lot....
Click here to download PS3 repair guide
Jan 04, 2011 | Sony Playstation 3 (PS3) Console
I have an iMac with a MATSHITADVD-R UJ-85J drive. I have been trying to burn some dvds using the TDK 16x DVD+R discs, but I keep getting an error code 0x80020022). I have tried rebooting my computer and...
I am not sure of the age of your imac but most of the drives now need 52 or just maybe the dvd that you are trying to burn has ablock that will not net you copy plus with some drives the burner will lock up or do a overrun which will not let you make any more dvd copys,cd copys can still be done however. I hope this helps and good luck.
Jun 22, 2017 | TDK Electronics - Others
Icannot copy to cd/dvd. i have tried various different discs. but file will not fit error re occuring. help
If am correct , You are trying to copy a disk....
Normally we get this, when there is space problem.
The software you are using if Nero.. it uses a temporary caching files on your local hdd in my documents.
Try to free some space and see to it
Also If you using and external dvd-rw, you will need to see if the things you are trying to burn can be cached via usb . Normally when burning more than 7gbor more you get this error, Or else use an internal drive to burn the same
hope this may help you
regards
uttam
Dec 18, 2009 | Microsoft Windows XP Home Edition
SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE U2 40 PROMLEM
Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
Aug 06, 2009 | Sharp AR-275 Copier
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
May 21, 2009 | Sharp AR-275 Copier
Sylvania SRDV495 DVD-VHS
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
Mar 06, 2007 | Sylvania SRDV495
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
