Question about PfaFF Tiptronic 2030
I need step by step directions on how to sew a buttonhole on a Pfaff Tiptronic 2020
SOURCE: threading the machine
what is the setting to hem
Posted on May 12, 2008
SewExpress
  • 41 Answers
SOURCE: 2020 rotary hook continuous one direction pfaff tiptronic 2020
You are absolutely correct - your machine doesn't come apart much because it is an electronic machine. There really are very few moving parts in modern sewing machines - and the electronics are better left to a technician who's been specifically trained.
It sounds as if your machine is no longer in time (needle rubbing the plate as it goes around if I'm understanding correctly). While not really a "major" repair, unfortunately with computerized/electronic machines, retiming your machine is something better left to an authorized Pfaff technician.
If the needle struck metal as you were stitching/basting, there may also be a rough spot/burr on the hook that your technician will be able to smooth off as well.
Hope this helps get you back up and running soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
talk2ginny
  • 34 Answers
SOURCE: buttonhole on second side was only half the length of first side
Hi, did you buy the machine from a dealer - if so, I would take it back and ask them to show you how to do buttonholes again. It is also possible that, although the test buttonholes sewed out correctly, the automatic button sensor needs professional adjustment.
Before going back to the dealer, find the section in your manual that discusses buttonholes and read thru it very carefully. Pfaff machines are not intuitive, and the manual might describe a way to adjust the automatic buttonhole settings so they sew out correctly.
If you need more help, please repost and I'll try to help or put you in touch with a dealer who can help
Good luck, Ginny
Good luck, Ginny
Posted on Jan 31, 2009
  • 108 Answers
SOURCE: I need a manual for my Pfaff Tiptronic 2040 Sewing
i was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
SOURCE: Have a Pfaff 6270 tiptronic
Hi, well most often when this happens, it is either the Power Supply, or the Controller. However, it also maybe any one of a myriad of "Other" faults, that unfortunately display the same symptoms, ie: lights on, No go, No display..
The very best thing you can do is take it into a Pfaff authorsied servicing center, contact either a local or head office, and ask for a referral to a local service center.
now when there, ask them for a "Quote"as to the repair, and if the "Quote" seems acceptable to you then you have the option of repairing or replacing depending on costings.
Posted on Mar 20, 2011
I am wondering if it is possible to find the plugin on the foot pedal of a Pfaff Tiptronic 2020
Probably so, however, if may be easier to find a replacement for the ailing part. You may need to search for a donor machine or a foot control that matches your machine. You can also try replacing the entire foot control with a new replacement item.
Pfaff Tiptronic 2020 Parts
If you can't find what you need, contact them directly.
Jul 03, 2017 | PfaFF Sewing Machines
I'd like to download repair manual for Pfaff tiptronic 2020.
If an internet search is unsuccessful, you can try joining the Yahoo Group: Pfaff_fixit
Most of the group members have been repairing Pfaff machines for a long time.
Sep 26, 2015 | PfaFF Sewing Machines
Pfaff tiptronic 2020 locking up/cutting bobbin thread
try changing the needle
when sewing a project-- the needle & fabric & thread must be compatable
check to see if there is any burrs on the needle plate or on the bobbin case
always make sure every thread guide is used
make sure the bobbin is inserted correctly in the bobbin case
Mar 31, 2012 | Sewing Machines
How do i fix the tension on my pfaff tiptronic 2020
It sounds like you need to adjust the bobbin tension. There is a small screw on the bobbin case to tighten/loosen the thread's tension coming out of the case. Refer to the user manual on the procedure to set it.
Nov 28, 2011 | PfaFF Tiptronic 2040
Buttonhole on second side was only half the length of first side
Good luck, Ginny
Good luck, Ginny
Jan 08, 2009 | PfaFF Tiptronic 2030
Threading the machine
Feb 21, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
156 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
