Question about 10 10 Computer Network adapter Cable (MJ25M-8F)
Problem when i start my computer have a choice F1 and F2
When i start up windows, it says ..errorr..drive not found... press F1 to continue and f2 to setup. How can i remove it please?
  • Mrtal Jul 10, 2008
    I have dell dimension E310 Problem when i start up my computer i have to press f1 or f2
    Master:
  • 848 Answers
Just insert the xp cd and choose repair in it .......it will remove the error message
Posted on Jun 20, 2008
<span style="FONT-SIZE: 18px" id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblHeader" class="support1" itxtvisited="1"><b>Problem when i start my computer have a choice F1 and F2</b></span>
Posted on Aug 18, 2010
    Problem Solver:
Lan massenger is not working,on windowsxp on this there is avasti anti viruse try version is install..i was install lan messanger but it was not show on bottom task bar
Posted on Dec 23, 2014
How do I go to BIOS?
You can enter BIOS setup or UEFI firmware via traditional method: Boot the PC, while the firmware starts to run, press F2/F1(Fn+F1 or Fn+F2). However, computer boots fast, maybe you often miss the trick to press F2/F1(Fn+F1 or Fn+F2). You can enter UEFI firmware from windows 8 or 8.1.
Nov 02, 2016 | Computers & Internet
Please see attached photo, this is what's
what are you trying to do ?
a bit more information might be able to help you.
IE: what are you doing when this (pop up) occurs ?
and why are striking the F1 or F2 keys ?
Computer keyboards contain keys that, when pressed on their own or in conjunction with another key, provide shortcuts to performing functions, saving time and keystrokes.
On most keyboards, these are the function, or "F," keys that run along the top of the keyboard. "F1" and "F2" are members of this group.
F1 Function Key
Pressing the "F1" function key while you are in an application will bring up the application's help file.
Pressing it when you are not in Windows Explorer or on the desktop produces the "Windows Help" file.
If you are in an application and press the "F1" button along with the Windows button, you will get the "Windows Help" file.
F1 Function Key Combined With Other Keys
"F1" can be pressed with other keys to gain a variety of results and functions.
Press "F1" and the "Shift" key to start context sensitive help, or help for the application.
Use the "F1" key with "Alt" to go to the next field in an application.
Press "F1," "Shift" and "Alt" at the same time to return to the previous field in an application.
To display the Microsoft system information, press "Ctrl," "Alt" and "F1" at the same time.
F2 Function Key Clicking on an icon on your desktop and pressing the "F2" function key will put the icon into rename mode in the same way as right-clicking on the icon and scrolling to "Rename."
F2 Function Key Combined With Other Keys
"F2" when pressed with other keys combines functions commonly found in the application "File" and "Edit" menus.
To copy selected text, highlight the text and press "Shift" with "F2."
To view a print preview of a document, press "Ctrl" with "F2" when in a document.
To save a document, press "Alt," "Shift" and "F2 together when in the application.
To choose the open file command, press "Ctrl," "Alt" and "F2."
Apr 22, 2013 | Computers & Internet
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I was working on my computer this morning and it froze. I turned it off and restarted it. The screen was black. I then turned it off and restarted again. Said something like default press F1 or F2 to...
At this point, you have to get all your data removed from the hard drive and then install the operating system of your choice. If you need further assistance, please give us a call at 800-595-3564.
Jan 18, 2010 | Acer Aspire 5100-3357 Notebook
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to continue,...
Press F2 to enter the Bios, on the first screen navigate to the floppy A: drive select disable and the error should go away.
From the sounds of it your Floppy drive is damaged or just bad. you can take it for repair or purchase a new one fairly cheap and replace it yourself. But just disabling it should do the trick since floppy's are pretty much obsolete.
the recovery Disk wont help you unless its an error you get in windows itself btw.. (unless its a OS start problem which this doesn't seem to be)
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Secondary drive 0 not found
Hi there.
Sounds like the boot order has been changed in the bios.
The secondary drive sounds like the CD drive as most laptops only come with 1 HDD installed.
Change the boot order to the primary drive by Pressing F1 during startup when the ThinkPad logo is displayed..
Once in the bios change the boot order, save and exit, the computer will restart and boot from the hard drive, when you get into windows check to make sure that the CD rom recognizes CD/DVD's.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | IBM ThinkPad T20 2647 Notebook
Press F1 to continue and f2 to setup. How can i remove it please?
after pressing f2.....bios setup was opened.....go to drivers.....and than open diskette driver.....select off .....your problam is solve 1000%
Dec 05, 2008 | 10 10 Computer Network adapter Cable...
10 10 Computer Network adapter Cable (MJ25M-8F) Logo
1,412 people viewed this question
Top 10 10 Computer Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a 10 10 Computer Computer and Internet Expert? Answer questions, earn points and help others
