Question about JC Whitney - Audiosonic 3-way Custom-fit Overhead Sound Bar Car Speaker
6 by 9s
How do i fit 6 by 9 speakers into my saxo furio on the parcel shelf?
    Problem Solver:
  • 50 Answers
You will have to make a 6x9 templet and them you will have to cut it out.
Posted on Jun 20, 2008
How do you remove rear speaker covers in a 96 geo
are they fitted in the rear doors or the parcel shelf ,if there aree no visable screws to un do if door fitted then will have to remove the door panel , if on parcel shelf same thing if no screws visable then remove from underneath , hope this is of some help
Sep 29, 2014 | 1996 Geo Prizm
Where is the parcel shelf on a 2007 Mini Cooper
The parcel shelf is that flat area behind you head of the rear seat. Normally has speakers or junk on it. On hatch back cars it lifts up as you open the hatch.
Mar 28, 2013 | 2007 Mini Cooper S Convertible
How do you remove the rear speakers from a 2004 chevy impala?
Remove the rear seat. On later models remove the rear upper quarter panel by pulling down & out to disengage the retainer clips, then sliding the roof leg out from under the trim panel over the door. Detach the rear seat belts through the slot in the rear parcel shelf. Pry up the plastic clips securing the rear parcel shelf. Then lift up & out to remove it from the vehicle. Remove the speaker retaining screws or tabs. If the speaker seal has bonded with the metal shelf, hold the tabs & pry the housing away from the metal. Disconnect the electical connector & remove the speaker. Install in reverse order. Good luck!
Feb 22, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
Citroen saxo furio pwer steering fault. Started intermittently. now not working at all. initially not working when starting engine , then kick in with a **** whilst driving. then after parking and stopping...
Hi
is it leaking from anywhere, quite common o saxo's they leak from the steering rack, they have a small circular seal that go's and drips fluid out of the bottom.
It is also quite common on saxo's for the power steering pump to fail, it's the same on the peugeots, this is most likely the cause so get that checked first, you can get one off ebay for about £30 and they are fairly easy to fit.
Hope this helps
Regards
Dan
Jan 22, 2010 | 1989 Peugeot 405
Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
May 02, 2009 | GMC Jimmy Cars & Trucks
I am about to put my 6x9 speakers in my car. i would like a little advice if possible. it will not be a tricky job as all the connections have been done (by a car garage). all i need to do is put the...
Typically the best way would be to remove the interior trim piece from the shelf. Then have a friend hold the MDF board up from inside the trunk. Then run either screws or bolts/nuts through from the interior all the way through the MDF. Replace interior trim piece and it should be held in tight.
Another less intrusive way would be to use a strong adhesive, such as "Liquid Nails" to secure the MDF to the bottom of the shelf. You'd need to figure a way to hold the MDF to the bottom of the shelf for quite awhile (8-24 hours) to make sure their is good adhesion.
Jan 31, 2009 | Car Audio & Video
Changing Rear Speakers in a 1996 a4.
First remove the rear seat bottom cushion (grab the front edge roughly in the center of each seat position and pull up firmly, and it'll unclip and come out). Then fold down the rear seatbacks. Now, the side bolsters for the seats (between the seatbacks and the doors) have to come off. First, pull down strongly near the bottom (there's an upward-facing hook there that clips onto a ring and holds the bottom in place). Pull down and forward and it'll come off. Then slide your hand about 75% of the way up, and pop the bolster straight forward to pop out a retaining clip. Finally, you can remove the top of it from its mount, and you'll have the bolster out. Repeat for the other side.
Go into the trunk and look up at the bottom of the rear shelf. The harness plug for the third brake light is there - unplug it.
Now, back in the rear seat area, just grab the front edge of the parcel shelf and lift upward to pop it loose, and the whole thing will slide forward. Then you can remove your speakers.
Install is the reverse of disassembly.
Jul 30, 2008 | 1996 Audi A4
Wiring 6 X 9 Speakers
hi,
i m Ritesh Upadhyay , there is no sound driver in my computer.
so i want to download it.
Feb 18, 2008 | Pioneer DEH-P2500 CD Player
Peugeot 106
you could use existing speaker wire from original speakers.and or just run new wire thru plastic kick panels , thru plastic base boards theh thru plastic rear kick panel ,thru rear seat ...
Dec 08, 2007 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Car Audio & Video Logo
260 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
