Question about Toshiba Satellite A135 Notebook
Usb ports since i bought my A135 pc, the usb ports have refuse to recognise any flash drives or printer. i have tried toshiba support centre with no solution
    Genius:
  • 2,028 Answers
Check to see if your flash drive or printer needs drivers in order to work properly. If not, then it could be the drivers for the usb ports or you have faulty usb ports. They're supposed to catch it at the factory, but it happens from time to time on new machines.
Posted on Jun 20, 2008
Flash drive won't work in usb ports unless i disable the 2.0 ehci controller
your laptop does not have enuf power to run the flash drive as faster usb 2.0 speeds.
Dec 26, 2009 | Toshiba Satellite A135-S2386 Notebook...
I have a Toshiba Settelite A135-S2386 laptop. When I plag in my memory stick, it says one of the usb attached to this computer is not recognised yet the same stick can be accessed through other computers....
Three things to try -
1 If you have more than 1 usb port try all of them.
2 Switch the laptop off and remove the battery for 30 minutes, replace and try again.
3. Try a different memory stick
Oct 30, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Does the toshiba satellite a135 s2276 accomodate a second hard drive?
You won't find internal room to place a second hard drive, if that's what you're asking. Most laptops simply do not have the internal space, especially thin-line units.
What you could do for extra storage space is purchase an external drive.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
USB drives Not working
this problem seems mostly with the usb mouse, the best solution is to plug the flash drive in one port and usb in other and restart the computer generally this always works but if it wont work then the best thing is i also did that, buy a 4-port usb hub and connect it with laptop and connect your usb mouse with this port not directly to your laptop and when you like to use your flash drive plug it in the laptop.
this is working with be perfectly and i hope it will do the same at your side.
Mar 23, 2009 | Toshiba Satellite A135-S2326 Notebook
Toshiba Satelite a135 s2386 USB problems...
this is the fault of your usb port, its a hardware problem, its better not to use that port, use a usb hub if you want more usb ports
Nov 11, 2008 | Toshiba Satellite A135-S2386 Notebook
USB ports not working
check the status of usb port on device manager, install the updated usb driver
Oct 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
