Question about Samsung Cell Phones
How do i set up m browser setting so i can have access to the net and vodafone
    Brigadier General:
  • 7,752 Answers
You need to contact vodafone customer care support line and have them assist you with the issues that you are having connecting to the web
Posted on Jun 20, 2008
Cant get web browser on my juno with boost mobil service
if you are using a phone that was not originally intended for that network your web browser will be set to run on the intended net work and will not run on another unless you are able to change it in your settings which you may or maynot be able to do.
eg telecom phone will not have internet access when a vodafone sim is inserted but will if you put in a telecom one or if you can change the settings to run vodafone internet.
if it appears you can change it, ask your network provider what you need to change your settings to.
Feb 24, 2011 | Cell Phones
Manual gprs settings for samsung model GT 15503 for vodafone
contact vodafone customer care executive and get the settings sir. this is easiest way of getting soon the settings. thank you sir
Jan 12, 2011 | Samsung Cell Phones
I have a Samsung GT S5233A handset with vodafone live enabled, I am able to browse internet in my handset, but I want to browse it through my pc windows xp, give me the settings for both my phone and pc
TRY ONE OF THE BELOW SETTING
1)To set up GPRS: a) Go to menu > Funbox > WAP Browser b) Select settings, and choose your profile Once you´ve selected the profile, complete the following fields: Profile name: Vodafone live! Homepage url:http://live.vodafone.in Security: Non-secure Bearer: GPRS IP address: 10.10.1.100 U sername: ______ Password: ______ APN: portalnmms Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WAP Browser > Home To set up MMS a) Go to menu > Messages b) Then go to Multimedia Messages > MMS Profile > choose your profile Profile name: Vodafone live! Homepage url:http://live.vodafone.in Security: Non-secure Bearer: GPRS IP address: 10.10.1.100 Username: ______ Password: ______ APN: portalnmms
2) a) Go to menu > Browser > Proxy settings b) Choose your profile Once you´ve selected the profile, complete the following fields: Profile name: Homepage URL: Bearer: GPRS Proxy use: Enabled GPRS setting: IP address: IP Port:9401 APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Browser b) Then go to current proxy, and select the desired proxy setting Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WWW services > Home
3) a) Go to menu > Settings b) Then go to Connection settings, and click on New Also, complete the following fields: Profile name: Homepage URL: Proxy: GPRS setting: IP address: Port:9401 Bearer: Advance setting: APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Browser b) Go to WAP profile, and select the desired proxy setting c) Then go to Options and click on Activate Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> > Browser > Home To set the proxy settings for MMS, go to: a) Menu > Messaging > Settings b) Go to Multimedia Messages, and select your profile c) Go to desired proxy settings, click on Options and select Activate Top X620, X650 To set up GPRS a) Go to menu > Funbox > WWW services b) Select Proxy Settings, and choose your profile Once you´ve selected the profile, complete the following fields Profile name: Homepage URL: Bearer: GPRS Proxy use: Enabled GPRS setting: IP address: IP Port:9401 Advance setting: APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Funbox > WWW services b) Then go to current proxy, and select the desired proxy setting Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WWW services > Home To set up MMS a) Go to menu > Messages b) The go to Multimedia Messages > MMS Profile > Profile settings > choose your profile
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
I can not get the interent to work with vodafone nz can you help
If it is that applications won't access the internet then mabey you need you need to activate your JAVA as follows... Menu button -> settings-> phone settings -> connectivity -> java settings -> add new -> Service Name = VF JAVA Connection Mode = TCP without proxy Access Point = Vodafone Live Save it and it activates. Good Luck! Rickenbacker
Feb 12, 2010 | LG KU990 Viewty
Htc 3300 vodafone pay as you go
first of all call vodafone to activate GPRS, then go to start>settings>settings>connections to configure and use the internet service
Jun 07, 2009 | HTC P3300 Smartphone
My phone was whith t mobile after unlocking i can not go on internet using my vodafone sim
You will need to change the internet settings on the phone as it will still be looking for the t mobile server, which the vodafone sim won't let it go to.
Normally the easiest way to do this is via the Vodafone website in your country. Once you log in, you should be able to get the correct settings sent to your phone via SMS, which you simply save to the phone. If you can't find it, or access the net, just ring Vodafone Customer Service and they will SMS the correct settings to you.
Apr 20, 2009 | LG KU990 Viewty
Cect i 9 internet set up and coverage prob for vodafone australia
UK WAP gateway settings
The following table shows basic WAP gateway setup information for the main UK mobile phone operators. The menu options differ between handset manufacturers. Some of the common menu fields explained:Bearer type: There are two types: GSM or GPRS. GSM works by dialling a dedicated WAP dial-up number and should work on any WAP-enabled handset. GPRS is a newer technology, and only works on selected handsets. GPRS is an always-on service that is billed per-kilobyte, and not as GSM, which is billed per-minute. Dial-up number - The telephone number that your WAP browser needs to dial to connect. (Not required for GPRS)
  • GPRS APN - If connecting over GPRS (as opposed to dial-up), you need an Access Point Node address, so the network knows where to direct your request. See our GPRS for full UK GPRS settings
  • Username and password - Note that these are case sensitive, and should be typed in as shown
  • Gateway IP details - WAP works by routing traffic through a Gateway that handles optimising the content efficiently. The address is made up of a series numbers separated by dots. This may also be referred to as the WAP Proxy Server address.
  • Homepage - This is the main page provided by a network operator... The front-door for access to content provided via your network operator
  • Below is the numbers you will need.
  • GSM Dial up Number>+447836 900808
  • GPRS APN>wap.vodafone.co.uk (Contract) pp.vodafone.co.uk (PAYG)
  • Username>user@vodafone.net or web will post the rest
Apr 20, 2009 | Cell Phones
Hi i have a sony ericsson k770i, i attempted both automatically and manually inputting settings for Vodafone United Kingdom for internet browsing. Neither solution worked, and google is still set as the...
Although this may sound pretty stupid when was the last time you accessed the Vodafone Live! UK section? I know a friend who has been having the same problems recently but there was something wrong with the connectivity in his area the other day (he lives just below London).
Apr 01, 2008 | Lands Phones
I CAN'T SEND AND RECEIVE MMS MESSAGES
call the company who your sim card is with, and they will give you settings to setup MMS (and internet access if required).
it needs to be setup through them!
Mar 26, 2008 | LG KS20 Smartphone
Cell Phones Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
