Question about Cameras
My camera won't turn on I have put in new batteries
  • Satdeep Marwaha May 11, 2010
    Please mention the camera make and model number. Both will be on the camera, most probably in the front.
    You will receive a more specific and workable solution with that.
    Satdeep.
Casio Exilm, EX S880
Posted on Aug 22, 2008
Put in new battery and it won't turn on
Hello, Hard to tell with info given, Try new battery to determine if it is battery related or a camera failure, Batteries are cheaper than camera repairs.
Hope this helps, Russell
Dec 10, 2012 | Kodak EasyShare Z612 Digital Camera
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
The camera ran out of battery and I put in 4 new alkaline batteries. Now the camera won't turn on at all.
Unless the batteries are in wrong they must be dead. try to use new ones and check for the instalation some of these cameras use wierd configurations on which is positive and what is negative.
May 25, 2011 | Nikon Coolpix L110 Digital Camera
My camera won't turn on...it is brand new
Brand new as in you just opened it out of the box? If thats the case you have to charge the re-chargeable battery first, then put it in the camera and it should work fine. Try giving the battery a charge first if you haven't already.
May 21, 2011 | Polaroid i1237 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Problem when starting up sony cybershot W55.
Your problem is mainly like above.
If you want to check the other troubleshootings please download the user manual of Sony Cyber-Shot DSC-W55
Feb 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Display not open [I X U S 70]
There is small switch under the battery lid near by the battery. Use a tooth stick to press the switch down and turn on the unit. If the unit won’t turn on you need a new main board.
Apr 05, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera won't retrack
August - this sounds like the same problem I had with my Finepix510. Turns out the new unopened package of batteries I put in weren't fresh enough and weren't working. When I got truly fresh batteries, everything started working just fine again.
Hope that turns out to be true for you.
Dec 28, 2007 | Fuji FinePix E510 Digital Camera
Cameras Logo
113 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
