I have a Kenmore Side by Side refrigerator Model # 536323. Recently, my ice maker just stopped working and I just noticed, after trying to turn it off then on, that the red light next to the on/off switch is blinking. Does anyone know what this light is for and if it is telling me what is wrong? I regularly change my filter and I am still getting cold water coming out. HELP!!!
SOURCE: Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
SOURCE: My Kenmore refrigerators (model #79177990) ice
Ice inlet tube may be frozen up inside of Fridge. Thaw it out with a hair blower. Shut of water supply and disconnect the water line that goes into the back. Use a flexable item at the connection to see if will go all the way through to the icemaker. I used a zip tie.
If you still don't have water going to the icemaker, you may need to replace the "Water Inlet Valve" at bottom back right of your Fridge. Easy to Do.
Yes, the ice bucket is in the door
same
Seem to have the same problem as described above. my Kenmore is Model # 56534400 though. Thanks.
Same problem as described above. My Kenmore is Model # 56534400 though. Thanks
