Question about Harman Kardon AVR 125 Receiver
HK avr125 5.1, no display, no functions.
My HK avr125 has no display and no functions except the input indicators and the surround mode indicators light up. There is no functions at all, I tried to reset the unit but that did not help.
I did find that there is no -30 volts going to IC74. My question is how is the -30 volts being generated at Q901.
Jeffrey Williams
  • jimmygourd Sep 13, 2008
    I have the same issue with my avr125. Just stopped working at all. Have you come up with a solution yet?
  • jb16rd Apr 14, 2009
    I have the same problem. Just no display but the unit does turn on.
    I found that the C901 cap on the power supply is scorched but I could barely tell but it is for sure toast. I am going to replace it and post here how it turned out
    Jerry
Same problem. C901 on the vertically-mounted input board next to the power supply transformer was burned. Replaced with ceramic cap from RS with same specs. Still did not work. Talked to Jeb, great guy at HK tech support. He suggested that R901 would probably be blown and maybe 902 also. These are flame-proof resistors and do not show damage. Tested with multimeter and Jeb was spot on. Replaced 1w resistors with 5w (all RS had) at same resistance. Works great.
Posted on Sep 27, 2009
  • jb16rd Dec 21, 2010
    AND you my friend are spot on also...
    both R901 and R902 showed open when reading with a meter. so they were both bad but looked good. I replaced them with what they were (.47ohm) and the cap that was visibly blown and everything is back working and in good order and I am watching TV again in surround..
    Thank you my friend.
    I didn't see your post til just this morning when I decided to start looking again at getting it fixed and ran across my old post.. I wonder why it never emailed me???
    All well, it's fixed now... Thanks again
    Jerry
  • Laser Plus Computers Mar 20, 2011
    i had a dirty switch on transformer bd. it is a reset switch. unit powerd on then off. lost all presets. contact cleaner in switch repaired my avr 230. glad it was not the regulator module like i thought. just a dirty switch causing erractic behavior. resetting tone button did not work.also tryed like 5 times to clear memory. it sings again!!
    Problem Solver:
  • 5 Answers
Hk 230 lost presets, erractic. will not power on goes off quick. . last time sprayed contact cleaner all connectors & bd. connections & it worked. A year later this time the same symtoms. switch on the module connects to transformer caused the receiver to reset. & lose all presets. it is a reset switch i also found out after i fixed it.. sprayed contact cleaner in switch that & it sings again. thank you to the person that suggested this in some site..mine is fixed!!!!
Posted on Mar 20, 2011
How do I fix my audio/video receiver that has no sound coming out of it?
If your unit has a speaker protection mode (5-8 second delay when 1st turned on) defective speakers and/or speaker wiring may be causing the protection circuit to do its job...protect the speakers. Disconnect all speakers and test HK in all modes (tuner, CD, DVD, etc.) using headphones. If you still cannot hear audio then it's time for a shop repair. Although I recommend factory authorized service whenever possible, a "local" shop that is certified by other well-known brands may be an option. If Yamaha, Onkyo or Luxman certified your local repair shop then it's a sure bet that they can properly repair HK's no longer under warranty.
Mar 22, 2015 | Harman Kardon AVR 340 Receiver
HK AVR 125 display strobing and no sound, even in headphone jack
Hi...
Find someone that does TV or audio repair and have them open it up. A cable assembly may have loosened during the MOVE.
Cheers
Jan 30, 2014 | Harman Kardon AVR 125 Receiver
All display lights are illuminated but device doesnt work
Do you hear the speaker protection relay click after about 10 seconds when you turn the receiver on? Does the display show PROTECTION on the display? These conditions indicate a bad channel that will keep the receiver from functioning but you still have lights. Steve
Jan 14, 2014 | Harman Kardon HK 3380 Receiver
I have a Marantz SR 8001. The front display lights went completely out, but the blue lights over the selector knob, volume knob, and the HDMI blue light comes on. I was setting up a Logitech 1100 remote...
You have a nice piece of Stereo...I believe you have mistakenly selected the" display mode OFF" function..,Here is the info that you can reactivate it..
If you need a soft User Manual here is the link for it too..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)...please insert some words in "
My Testimonials "
Hope this helps!
" display mode OFF"
You can select the display mode for the front display
of the SR7001.To select this mode, press the DISPLAY on the remote control or the front panel.When this button is pressed, the display mode is switched in the following sequence.Input Mode ? Surround Mode ? Auto display OFF ? Display OFF ? Normal Mode ? Input Mode Normal Mode: Displays the selected input function. If the function has been renamed using the Function Rename feature (see page 26), the renamed name appears on the display. Input Mode: Displays the input mode set via the Function Input Setup feature (see page 25). Surround Mode: Displays the status of the selected surround mode. Auto Display Off mode: The display is off. But, if you make a change to the unit such as the input or surround mode, the display will show that change, then go back to off after about 3 seconds. When changing the volume, it is not displayed. Display Off mode: The display is off completely. Note: • Only the DISP indicator will be illuminated on thefront display in display off condition
http://www.scribd.com/doc/53431794/Marantz-SR-8001-Owners-Manual
Jun 23, 2011 | Marantz SR8001
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
Sony STR DE845: rear speakers not working, three fronts are OK.
The rear amp is malfunctioning (duh). Take it to a tech for a real diagnosis.
Sep 05, 2009 | Sony STR-DE845 Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Apr 21, 2009 | Denon AVR-1802 Receiver
No sound on digital inputs
do you get sound when on FM? but not on test tone! check all speaker connections, spkrs are on and if thats good you may have to do some digital input assigning, let me know I can help with that
Feb 20, 2009 | Denon AVR-1604 Receiver
Yamaha HTR-6030
The indicator is telling you you have a 2-channel input. You may have the Blu-Ray connected wrong. Or the source is only Stereo. I need more details to assess that.
The sound coming from all speakers is normal if you have any surround mode selected, regardless of the characteristics of the source
I imagine if you experiment you might find all speakers playing for any number of 2-channel sources, not just Blu-Ray. Besides actual Pro Logic decoding, the various surround modes can provide some interesting effects on non Dolby Surround material.
I recommend that you try them all on various recordings and you may find one or another of them preferable over vanilla stereo. I find that any given artist or music type, even within a given CD, may sound 'better' with different surround settings.
Dec 27, 2008 | Yamaha HTR-6030 Receiver
Harman Kardon AVR 125 Receiver Logo
523 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
