Question about Onkyo Audio Players & Recorders
I need a woofer for my Onkyo stereo. It is from a SK-60 12" 4 Way speaker; P/N 310057. Anybody know where I can order one of these from, or would it be cheaper to have it repaired...it buzzes on the really low parts.
It is to have it check first maybe it is still repairable. you can look for made to order shop in your locality if you want to buy. thank you.
Posted on Jul 02, 2008
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
My onkyo reciever (tx-ds656) powers on, then after a couple seconds says "protect" and powers down. why is this happening? rmill24@yahoo.com
"protect" comes on for 4 reasons.
1. crossed or damaged speaker wires- make sure that the positive and negative is not crossed at all. inspect the wiring for any loose strands of wire that might be crossed, touching the speaker frame or touching the metal case of the amp. look for any damage to the wires. use new speaker wires, if you need to.
2. improper speaker ohmage- verify that your speakers are 8 ohms or greater. ohmage is usually labeled on the back of the speaker, and will have the greek letter "Omega" ω next to the ohmage rating. example: 8ω or 16ω.
3. blown speaker- push in on the woofers, it should move freely for an inch or 2 before bottoming out. if it feels like its scratchy or rubbing or there is any resistance before it bottoms out, then the speaker's voice coil is melted.
4. blown amp.
Nov 07, 2010 | Onkyo TX-DS656 Receiver
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
How do I connect my Acoustimass® 5 Series III Stereo Speaker System to my Onkyo SR506 av receiver?
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Oct 28, 2009 | Bose Acoustimass 5 III System
I need speakers for my Onkyo A-911M integrated amp
A+B speakers = 4 channels 2 right 2 left
100 watts/4 = 25 watts per channel
RMS watts / channel = 25 x .707 = 18 watts/channel which is your average consumer stereo system
I would use 8 or 16 ohm speakers (not 4 ohm) -- almost any set of stereo speakers will "work" -- these will be 8 ohm and about 5 watt minimum / 40 watt max thereabouts
May 07, 2009 | Onkyo Audio Players & Recorders
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
Onkyo TX-SV525 Receiver subwoofer pre out no sound
Yes turing on the "A" speaker is required for the Onkyo, but that only turns on the 2 front speakers in the "A" speaker jacks.
You may also need to check and see if the Onkyo has a menu selection in the setup menu that will turn on the sub woofer output on the back of the receiver.
I have seen on countless occasions where people just have a hard time finding that sub woofer option on their receiver.
I do not have the manuals for this Onkyo, so I can not tell you the exact way to find it.
I have been repairing surround receivers since they have been on the market and beleive me, you are not alone in this situation.
Sometimes it seems like you need a Phd. in programming or something similar just to firgure out how to set one of these up.
The solution should be in your owners manual, with the problem then being, just where in the manual. Go slowly thru it paying the closest attention to anything about set up procedures.
I have also seen at times where the setup for the sub-woofer is not listed as sub-woofer, but as "LFE" (low frequency effect) . So keep your eyes open for that.
something else, your sub woofer may have an auto turn on. That means it will only turn on if it detects an input signal. Make sure yo uhave the volume up enough on the receiver to trigger that auto turn on if yours has one.
I would like to have been more help, but without the manuals I can only give you general type thngs to look for. These type of receivers are all so different and all so complicated to operate. The days of just turning on a stereo, selecting your source and turning up the volume seem to be over.
Let me know if you need any more assistance from me.
Dave
p.s. Very nice system you have, when you get the Kef working I think you are going to just love this system. and Onkyo has the best quality receivers in their price range.
Jun 27, 2008 | Onkyo TX-SV525 Receiver
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
47 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
